简介
Use this guide to repair the power supply with a Phillips head screwdriver, a wrench, and pliers. These tools will help secure the screw holding the wire.
First, to remove the plastic bracket, turn toaster oven on its side.
  • First, to remove the plastic bracket, turn toaster oven on its side.
添加评论
Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
添加评论
If the wire gets pulled out of the transformer, reinsert it.
  • If the wire gets pulled out of the transformer, reinsert it.
  • Use a small flathead screwdriver to secure the screw that holds the wire in place.
添加评论
结论
Tony Wang
于2012年10月05日注册
64 信誉积分
创作了5篇指南
团队
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G35
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 665
