跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何启用电池存储模式
  1. 如何启用电池存储模式, 启动到BIOS: 步骤 1 中的图像 1,1
    • 关闭你的Steam Deck电源
    • 在电源关闭之后,长按音量提升(+)键并按下电源
    • 松开所有按键
    • Steam Deck应会开机,启动到BIOS菜单。
  2. 如何启用电池存储模式, 启用电池存储模式: 步骤 2 中的图像 1,3 如何启用电池存储模式, 启用电池存储模式: 步骤 2 中的图像 2,3 如何启用电池存储模式, 启用电池存储模式: 步骤 2 中的图像 3,3
    • 在BIOS中,使用D-Pad来引导然后用A键来选中
    • 引导到Setup Utility菜单
    • 引导到Power菜单
    • 选中Battery storage mode
    • 选中Yes来确认。
    • 你的Steam Deck应会关闭电源进入电池存储模式。
    • 处于存储模式下,你的Steam Deck将不会响应点击开机键的任何操作。要退出存储模式,将充电器插入你的Steam Deck。
结论
要退出电池存储模式,请将你的 Steam Desk 插入充电器。
维修没有按计划进行? 尝试一些 基本故障排除,或向我们的 Steam Deck 社区寻求帮助。
77等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Carsten Frauenheim
于03/10/20注册
112,911 声望
创作了338篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,734篇指南
13条评论
I thought that this mode is also for when you not going to use your Steam Deck for more than a week. And if so, what is the percentage of battery you should leave the Steam Deck with before putting it in storage.
Uzi Batish - 回复
The help page valve provides via the device indicates not to engage the mode above 80% state of charge.
From my personal experience with other devices and the state of charge the device ships at, I'd recommend something around 50% to 60% as a desirable storage point for best battery life during long-term storage
bensmith88 -
Lithium batteries usually needs to be stored at around 50% SOC, however when you want to store such a battery, you also have to keep in mind the self discharge rate, and the fact that once over-discharged (even through self discharge) a lithium based battery could be dead and should never be recharged as it could burst in flame. That's why 60-65% is a good choice, as it will allow you to store it a lot longer without reaching over discharge state.
Adrien ASESIO - 回复
Help! I followed these instructions to a T and also replaced my SSD following that guide to a T and now I'm presented with this message:
"Default Boot Device Missing or Boot Failed. Insert Recovery Media and Hit any key
Then Select 'Boot Manager' to choose a new Boot Device of to Boot Recovery Media."
I don't know what any of this means and I can't find a single straight answer anywhere.
Dane H - 回复
You need to install an OS.
See Valve's instructions - https://help.steampowered.com/en/faqs/vi...
Rich -
添加评论
浏览统计数据:
过去 24 小时: 145
过去 7 天: 979
过去 30 天: 4,752
总计 150,079
