跳转到主内容
How to Dye a Used Shirt
你所需要的
  1. How to Dye a Used Shirt, How to Dye a Used Shirt: 步骤 1 中的图像 1,2 How to Dye a Used Shirt, How to Dye a Used Shirt: 步骤 1 中的图像 2,2
    • The dye used for this guide is Rit DyeMore.
    • Buy the product and make sure to read the instructions on the bottle.
    • Weigh your shirt & follow instructions on the bottle according to weight to determine how much dye is needed.
    • Pre-wash your clothing item and prepare your materials and work area.
  2. How to Dye a Used Shirt: 步骤 2 中的图像 1,1
    • Add enough water in a stainless steel pot to let the clothing item move freely. This is shown by the clothing floating within the pot.
  3. How to Dye a Used Shirt: 步骤 3 中的图像 1,1
    • Add 1 tsp of dish detergent to the pot.
  4. How to Dye a Used Shirt: 步骤 4 中的图像 1,1
    • Cover the pot and let the water reach close to boiling temperature ~200 degrees Fahrenheit.
  5. How to Dye a Used Shirt: 步骤 5 中的图像 1,1
    • Add the desired amount of dye that was measured via the bottle to the water and turn the stove top temperature to simmer.
  6. How to Dye a Used Shirt: 步骤 6 中的图像 1,2 How to Dye a Used Shirt: 步骤 6 中的图像 2,2
    • Place wet clothing item in the solution.
    • Stir slowly for 10 minutes.
  7. How to Dye a Used Shirt: 步骤 7 中的图像 1,2 How to Dye a Used Shirt: 步骤 7 中的图像 2,2
    • After the desired color is achieved, remove the item from the solution.
    • Rinse the clothing item with warm water .
    • Gradually use cooler water until the water runs clear.
    • To finish, wash clothing item in warm water, dry and enjoy your new clothing item!
结论
Enjoy your new wardrobe!
2等其他人完成本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 206
