跳转到主内容
How to Disconnect a Car or Truck Battery
你所需要的
  1. How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 步骤 1 中的图像 1,3 How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 步骤 1 中的图像 2,3 How to Disconnect a Car or Truck Battery, How to Disconnect a Car or Truck Battery: 步骤 1 中的图像 3,3
    • Before you begin, switch the ignition off and remove the key.
    • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
    • Put on work gloves and safety goggles if you have them available.
    • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
    • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
  2. How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 步骤 2 中的图像 1,3 How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 步骤 2 中的图像 2,3 How to Disconnect a Car or Truck Battery, Open the hood (bonnet): 步骤 2 中的图像 3,3
    • Most motor vehicle batteries are located in the engine bay, under the hood (a.k.a. bonnet). If your battery is located elsewhere, skip to Step 5.
    • If you're not sure, simply continue reading.
    • Pull the hood release lever. It's usually located inside the car, near the steering wheel.
  3. How to Disconnect a Car or Truck Battery: 步骤 3 中的图像 1,3 How to Disconnect a Car or Truck Battery: 步骤 3 中的图像 2,3 How to Disconnect a Car or Truck Battery: 步骤 3 中的图像 3,3
    • Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
  4. How to Disconnect a Car or Truck Battery: 步骤 4 中的图像 1,3 How to Disconnect a Car or Truck Battery: 步骤 4 中的图像 2,3 How to Disconnect a Car or Truck Battery: 步骤 4 中的图像 3,3
    • At this point, depending on the vehicle, your hood may raise and support itself automatically.
    • If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
    • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
    • Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
    • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
  5. How to Disconnect a Car or Truck Battery: 步骤 5 中的图像 1,3 How to Disconnect a Car or Truck Battery: 步骤 5 中的图像 2,3 How to Disconnect a Car or Truck Battery: 步骤 5 中的图像 3,3
    • Locate the battery. It's normally rectangular and roughly 8-14" across.
    • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
    • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
  6. How to Disconnect a Car or Truck Battery: 步骤 6 中的图像 1,3 How to Disconnect a Car or Truck Battery: 步骤 6 中的图像 2,3 How to Disconnect a Car or Truck Battery: 步骤 6 中的图像 3,3
    • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
    • Always disconnect the negative cable first (before removing the positive cable).
    • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
    • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
  7. How to Disconnect a Car or Truck Battery: 步骤 7 中的图像 1,2 How to Disconnect a Car or Truck Battery: 步骤 7 中的图像 2,2
    • Remove the cable from the negative battery terminal.
  8. How to Disconnect a Car or Truck Battery: 步骤 8 中的图像 1,2 How to Disconnect a Car or Truck Battery: 步骤 8 中的图像 2,2
    • Prevent the cable from making accidental contact with the terminal by pushing it aside and/or wrapping the cable clamp with a dry rag.
结论
4等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
428,107 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 105
总计 26,358
