跳转到主内容
How to Descale a Nespresso VertuoPlus
你所需要的
  1. How to Descale a Nespresso VertuoPlus, How to Descale a Nespresso VertuoPlus: 步骤 1 中的图像 1,1
    • Turn the machine on by pressing the button with a coffee mug logo.
  2. How to Descale a Nespresso VertuoPlus: 步骤 2 中的图像 1,3 How to Descale a Nespresso VertuoPlus: 步骤 2 中的图像 2,3 How to Descale a Nespresso VertuoPlus: 步骤 2 中的图像 3,3
    • Lift the lever upwards to remove any used capsules from the machine.
    • Empty the capsule container that is located at the back of the machine.
  3. How to Descale a Nespresso VertuoPlus: 步骤 3 中的图像 1,1
    • Turn the machine off by pushing the same lever down.
  4. How to Descale a Nespresso VertuoPlus: 步骤 4 中的图像 1,1
    • Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
  5. How to Descale a Nespresso VertuoPlus: 步骤 5 中的图像 1,1
    • To access the descaling mode on the machine, push both the button and lever down for three seconds.
    • You will see an orange light, indicating that you have reached the "Special Functions" menu.
  6. How to Descale a Nespresso VertuoPlus: 步骤 6 中的图像 1,1
    • To access the descaling mode, press the lever down one time.
  7. How to Descale a Nespresso VertuoPlus: 步骤 7 中的图像 1,1
    • To start descaling, push the button.
    • An orange light will start to blink indicating the descaling function.
    • The machine will stop automatically when completed.
  8. How to Descale a Nespresso VertuoPlus: 步骤 8 中的图像 1,1
    • Empty the descaling liquid from the water tank.
    • Rinse and clean the tank thoroughly.
  9. How to Descale a Nespresso VertuoPlus: 步骤 9 中的图像 1,1
    • Fill the water tank with fresh water and place it back into the machine.
  10. How to Descale a Nespresso VertuoPlus: 步骤 10 中的图像 1,1
    • Push the button to rinse the machine.
  11. How to Descale a Nespresso VertuoPlus: 步骤 11 中的图像 1,1
    • To exit descaling mode, press both the button and lever at the same time for three seconds.
  12. How to Descale a Nespresso VertuoPlus: 步骤 12 中的图像 1,1
    • A green light will show, indicating the descaling has been completed successfully.
终点
45等其他人完成本指南。
Olivia peet
于02/15/21注册
1,285 声望
撰写一个指南
团队
Texas Tech, Team S3-G18, Cowan Spring 2021 Texas Tech, Team S3-G18, Cowan Spring 2021 的会员
TTU-COWAN-S21S3G18
1 名成员
创作了7篇指南
12指南评论
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
James Spavelko - 回复
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
Laura Retana -
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Attilio Carioti - 回复
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Luca Levra -
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
maria.padovano1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 54
过去 7 天: 367
过去 30 天: 1,673
总计 219,038
