跳转到主内容
How to Descale a Nespresso Vertuo
你所需要的
  1. How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 步骤 1 中的图像 1,3 How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 步骤 1 中的图像 2,3 How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 步骤 1 中的图像 3,3
    • Lift the machine head to ensure there are no capsules present inside.
    • Empty the capsule container by removing it from the machine and disposing of any used capsules.
  2. How to Descale a Nespresso Vertuo: 步骤 2 中的图像 1,3 How to Descale a Nespresso Vertuo: 步骤 2 中的图像 2,3 How to Descale a Nespresso Vertuo: 步骤 2 中的图像 3,3
    • Fill the water tank halfway with fresh water.
    • Add 1 packet of the Nespresso descaling solution to the water tank.
    • Do not swallow or ingest the Nespresso descaling solution.
    • The Nespresso descaling solution may cause irritation to skin and/or eyes.
  3. How to Descale a Nespresso Vertuo: 步骤 3 中的图像 1,2 How to Descale a Nespresso Vertuo: 步骤 3 中的图像 2,2
    • To place the machine in descaling mode, begin with the lever in the unlocked position, parallel to the spout.
    • Press the button once and release it, then wait for the indicator light to turn on.
  4. How to Descale a Nespresso Vertuo: 步骤 4 中的图像 1,1
    • Press and hold the button until the indicator light turns off, and then begins blinking.
    • It may take approximately 7 seconds before the light begins to blink.
  5. How to Descale a Nespresso Vertuo: 步骤 5 中的图像 1,3 How to Descale a Nespresso Vertuo: 步骤 5 中的图像 2,3 How to Descale a Nespresso Vertuo: 步骤 5 中的图像 3,3
    • Rotate the lever to the left to secure it in the locked position.
    • Then return the lever back to the center to release the lock.
  6. How to Descale a Nespresso Vertuo: 步骤 6 中的图像 1,1
    • Press and hold the button until the indicator light turns off and then begins blinking again.
    • Steps 5 and 6 must be completed within 45 seconds of each other.
  7. How to Descale a Nespresso Vertuo: 步骤 7 中的图像 1,2 How to Descale a Nespresso Vertuo: 步骤 7 中的图像 2,2
    • While the indicator light is blinking, rotate the lever to the left to place it in the locked position.
  8. How to Descale a Nespresso Vertuo: 步骤 8 中的图像 1,3 How to Descale a Nespresso Vertuo: 步骤 8 中的图像 2,3 How to Descale a Nespresso Vertuo: 步骤 8 中的图像 3,3
    • Place a large container (20oz+) underneath the spout.
    • Press and release the button once to begin dispensing the descaling solution.
    • The machine will intermittently dispense the solution. Once the cycle has finished running, the machine will be silent.
    • Discard the solution.
  9. How to Descale a Nespresso Vertuo: 步骤 9 中的图像 1,2 How to Descale a Nespresso Vertuo: 步骤 9 中的图像 2,2
    • Rinse out the water tank.
    • Refill the water tank until it's about two-thirds full of fresh water and place it back onto the machine.
    • Place the large container back under the spout.
  10. How to Descale a Nespresso Vertuo: 步骤 10 中的图像 1,1
    • Press and release the button one time to begin the rinsing process.
  11. How to Descale a Nespresso Vertuo: 步骤 11 中的图像 1,1
    • Once the machine is silent and the water tank is empty, discard the water from the large container.
  12. How to Descale a Nespresso Vertuo: 步骤 12 中的图像 1,1
    • To reset the machine for regular use, press and hold the button until the indicator light stops blinking.
  13. How to Descale a Nespresso Vertuo: 步骤 13 中的图像 1,1
    • Wipe the machine down.
    • Let the machine rest for 10 minutes.
    • The machine is now ready for use.
结论
By regularly descaling your Nespresso Vertuo machine, you are preserving its functionality and contributing to environmental sustainability. Keeping your machine in good working condition helps reduce the likelihood of it ending up in a landfill prematurely, minimizing the environmental impact of electronic waste.
To ensure optimal performance and longevity, Nespresso recommends descaling your machine every 3 months or 300 pods, whichever comes first.
Thank you for taking the time to follow this guide and for your commitment to maintaining your Nespresso machine. Here's to many more cups of great-tasting coffee!
另外一个人完成了本指南。
Rachel Davis
于02/19/24注册
235 声望
撰写一个指南
团队
CSU Sacramento, Team 1-10, Laflen Spring 2024 CSU Sacramento, Team 1-10, Laflen Spring 2024 的会员
CSUSAC-LAFLEN-S24S1G10
2 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 49
过去 30 天: 181
总计 2,971
