跳转到主内容
加入维修社区 - 创建账户
How to Descale a Keurig K-Mini
你所需要的
  1. How to Descale a Keurig K-Mini, How to Descale a Keurig K-Mini: 步骤 1 中的图像 1,1
    • Rinse and empty the water reservoir.
    • Make sure no k-cup is in the machine.
  2. How to Descale a Keurig K-Mini: 步骤 2 中的图像 1,2 How to Descale a Keurig K-Mini: 步骤 2 中的图像 2,2
    • Refill the reservoir with a solution that is about one-third distilled white vinegar and two-thirds water, to the MAX-fill line.
  3. How to Descale a Keurig K-Mini: 步骤 3 中的图像 1,2 How to Descale a Keurig K-Mini: 步骤 3 中的图像 2,2
    • Run a brewing cycle into a cup.
    • Empty the cup into the sink.
  4. How to Descale a Keurig K-Mini: 步骤 4 中的图像 1,1
    • Refill the reservoir again with the same solution, and start another brew cycle, but this time once the machine starts dispensing the first couple drops, power off the machine.
    • Let the solution sit in the machine for an hour.
  5. How to Descale a Keurig K-Mini: 步骤 5 中的图像 1,1
    • After an hour, hold the brew button down to empty the remaining solution from the water reservoir.
    • Avoid holding down the button too long after it is done dispensing, as you can potentially damage the water pump by forcing it to pump when there is no liquid left for it to pump.
    • Refill the reservoir with only fresh water, and repeat brew cycles to flush the solution out of the machine.
    • Repeat this process around 4-6 times to rinse the vinegar out of the machine.
    • If you taste any vinegar in your next brew, repeat the previous bullet.
结论
Depending on how often you use your device, you should repeat this procedure about once every 3-6 months to maintain good tasting coffee.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 139
总计 2,347
