跳转到主内容
How to Descale a Breville Barista Pro BES878-RVC
你所需要的
  1. How to Descale a Breville Barista Pro BES878-RVC, How to Descale a Breville Barista Pro BES878-RVC: 步骤 1 中的图像 1,1
    • Press the power button to power on the espresso machine.
  2. How to Descale a Breville Barista Pro BES878-RVC: 步骤 2 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 2 中的图像 2,2
    • Pull out and empty the water tank and drip tray.
  3. How to Descale a Breville Barista Pro BES878-RVC: 步骤 3 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 3 中的图像 2,2
    • Pull out the water filter from the water tank.
  4. How to Descale a Breville Barista Pro BES878-RVC: 步骤 4 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 4 中的图像 2,2
    • Pour a packet of descaler (or a descaler tablet) into the water tank.
    • Fill the water tank with fresh water to the descale line located on the side of the water tank.
    • If you do not have a descaler, pour a 1:1 mixture of white vinegar and water into the water tank instead.
  5. How to Descale a Breville Barista Pro BES878-RVC: 步骤 5 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 5 中的图像 2,2
    • Reinsert water tank and drip tray.
  6. How to Descale a Breville Barista Pro BES878-RVC: 步骤 6 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 6 中的图像 2,2
    • Position the steam wand above the drip tray.
    • If you wish to prevent splashing, place a tall bowl or cup under the steam wand.
  7. How to Descale a Breville Barista Pro BES878-RVC: 步骤 7 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 7 中的图像 2,2
    • Press the menu button.
    • Turn the knob labelled “Filter Size” counterclockwise until the “descale” label is blinking on the display.
  8. How to Descale a Breville Barista Pro BES878-RVC: 步骤 8 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 8 中的图像 2,2
    • Press down on the “Filter Size” knob to select descale.
    • The letter d will appear on the display and the one cup button will illuminate.
  9. How to Descale a Breville Barista Pro BES878-RVC: 步骤 9 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 9 中的图像 2,2
    • Press the one cup button to enter descale mode.
    • d3 will appear on the display and water will pour from the group head.
  10. How to Descale a Breville Barista Pro BES878-RVC: 步骤 10 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 10 中的图像 2,2
    • Wait for the display to show “d2.”
    • Rotate the right dial to the hot water icon to descale the hot water dispenser.
  11. How to Descale a Breville Barista Pro BES878-RVC: 步骤 11 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 11 中的图像 2,2
    • Wait for the display to show “d1.”
    • Rotate the right dial to the steam icon to descale the steam wand.
  12. How to Descale a Breville Barista Pro BES878-RVC: 步骤 12 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 12 中的图像 2,2
    • Wait for the display to show “r.”
    • Rotate the right dial back to the neutral position.
    • r means "rinse." You are now in the rinsing phase of descaling your espresso machine.
  13. How to Descale a Breville Barista Pro BES878-RVC: 步骤 13 中的图像 1,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 13 中的图像 2,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 13 中的图像 3,3
    • Pull out and empty the water tank.
    • Fill the water tank with fresh water to the max line.
    • Reinsert the water tank.
  14. How to Descale a Breville Barista Pro BES878-RVC: 步骤 14 中的图像 1,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 14 中的图像 2,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 14 中的图像 3,3
    • Pull out the drip tray.
    • Empty the drip tray.
    • Reinsert the drip tray.
  15. How to Descale a Breville Barista Pro BES878-RVC: 步骤 15 中的图像 1,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 15 中的图像 2,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 15 中的图像 3,3
    • Press the one cup button to initiate the rinse cycle.
    • “r3” should appear on the display.
    • Wait for the display to show “r2”.
    • Rotate the right dial to the hot water icon to rinse the hot water dispenser.
  16. How to Descale a Breville Barista Pro BES878-RVC: 步骤 16 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 16 中的图像 2,2
    • Wait for the display to show “r1.”
    • Rotate the right dial to the steam icon to rinse the steam wand.
  17. How to Descale a Breville Barista Pro BES878-RVC: 步骤 17 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 17 中的图像 2,2
    • Once the rinse is complete, the grind amount option will appear on the display.
  18. How to Descale a Breville Barista Pro BES878-RVC: 步骤 18 中的图像 1,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 18 中的图像 2,3 How to Descale a Breville Barista Pro BES878-RVC: 步骤 18 中的图像 3,3
    • Pull out the water tank.
    • Reinsert the water filter.
    • Refill the water tank with fresh water.
  19. How to Descale a Breville Barista Pro BES878-RVC: 步骤 19 中的图像 1,1
    • Pull out and empty the drip tray.
  20. How to Descale a Breville Barista Pro BES878-RVC: 步骤 20 中的图像 1,2 How to Descale a Breville Barista Pro BES878-RVC: 步骤 20 中的图像 2,2
    • Reinsert the water tank and drip tray.
    • Your expresso machine should be clean and produce better tasting drinks!
终点
Jeffery Huang
于09/07/23注册
301 声望
撰写一个指南
团队
York University, Team 1-14, O'Regan Fall 2023 York University, Team 1-14, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G14
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 76
过去 30 天: 282
总计 1,434
