跳转到主内容
How to Deep Clean a Mechanical Keyboard
你所需要的
  1. How to Deep Clean a Mechanical Keyboard, How to Deep Clean a Mechanical Keyboard: 步骤 1 中的图像 1,1
    • Take a picture of the keyboard for future reference.
    • This is to ensure that all keys return to the correct place.
  2. How to Deep Clean a Mechanical Keyboard: 步骤 2 中的图像 1,3 How to Deep Clean a Mechanical Keyboard: 步骤 2 中的图像 2,3 How to Deep Clean a Mechanical Keyboard: 步骤 2 中的图像 3,3
    • Use keycap puller to pull the keys off gently.
    • Some keys are harder to pull so adjust your strength accordingly.
    • Place them in the bowl.
  3. How to Deep Clean a Mechanical Keyboard: 步骤 3 中的图像 1,2 How to Deep Clean a Mechanical Keyboard: 步骤 3 中的图像 2,2
    • Flip the keyboard over.
    • Tap it and let all the dirt fall off.
  4. How to Deep Clean a Mechanical Keyboard: 步骤 4 中的图像 1,3 How to Deep Clean a Mechanical Keyboard: 步骤 4 中的图像 2,3 How to Deep Clean a Mechanical Keyboard: 步骤 4 中的图像 3,3
    • Scrub the rows with a dry toothbrush gently.
    • Use tweezer to get gunk out of hard to reach areas.
    • Scrub away any left over dirt that is still visible.
    • Use a cotton swab dipped in isopropyl alcohol for maximize cleanliness.
  5. How to Deep Clean a Mechanical Keyboard: 步骤 5 中的图像 1,1
    • Use a can of compress air to further clean the keyboard.
    • Use this in tight areas such as in between key switches.
  6. How to Deep Clean a Mechanical Keyboard: 步骤 6 中的图像 1,2 How to Deep Clean a Mechanical Keyboard: 步骤 6 中的图像 2,2
    • Fill the bowl with lukewarm water and add soap.
    • Use the toothbrush to gently scrub the keys.
    • Scrub all sides to ensure absolute cleanliness.
  7. How to Deep Clean a Mechanical Keyboard: 步骤 7 中的图像 1,2 How to Deep Clean a Mechanical Keyboard: 步骤 7 中的图像 2,2
    • Soak the keys in the soap bath for 5 minutes.
    • Rinse the keys with lukewarm water.
    • Make sure there is no soap left.
  8. How to Deep Clean a Mechanical Keyboard: 步骤 8 中的图像 1,3 How to Deep Clean a Mechanical Keyboard: 步骤 8 中的图像 2,3 How to Deep Clean a Mechanical Keyboard: 步骤 8 中的图像 3,3
    • Lay the keys letters-side up on the towel.
    • Let them completely dry.
    • Gather the towel corners and make a sack.
    • Shake the keys vigorously to ensure faster dry time.
  9. How to Deep Clean a Mechanical Keyboard: 步骤 9 中的图像 1,3 How to Deep Clean a Mechanical Keyboard: 步骤 9 中的图像 2,3 How to Deep Clean a Mechanical Keyboard: 步骤 9 中的图像 3,3
    • Use Step 1 to re-assemble the keyboard.
    • Test the keys to check for faultiness.
结论
Aye, you did it! Pat yourself on the back for the hard work you have done today. Hopefully, you will gain an understanding of how to maintain your keyboard. Thank you so much for choosing this particular guide. Have a wonderful day!
2等其他人完成本指南。
Capreil Joseph
于10/23/23注册
187 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 80
总计 320
