跳转到主内容
How to Darn a Hole in Denim Jeans by Hand
你所需要的
  1. How to Darn a Hole in Denim Jeans by Hand, How to Darn a Hole in Denim Jeans by Hand: 步骤 1 中的图像 1,1
    • Gather your jeans needing repair and locate the hole to be darned.
  2. How to Darn a Hole in Denim Jeans by Hand: 步骤 2 中的图像 1,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 2 中的图像 2,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 2 中的图像 3,3
    • Using a pair of scissors, trim away any loose and frayed ends.
    • These are ends that would have formed from the ripping of the denim fabric.
  3. How to Darn a Hole in Denim Jeans by Hand: 步骤 3 中的图像 1,1
    • Match a thread color to the color of the denim you are repairing.
    • For a sleeker and less visible repair use a thread with a smaller strand count.
    • I used a thicker and more visible color for the purpose of making the stitching easier to see in this guide.
  4. How to Darn a Hole in Denim Jeans by Hand: 步骤 4 中的图像 1,1
    • Cut a patch from a similar colored piece of denim.
    • The patch should be longer than the hole on all sides by at least 1/2 inch.
  5. How to Darn a Hole in Denim Jeans by Hand: 步骤 5 中的图像 1,2 How to Darn a Hole in Denim Jeans by Hand: 步骤 5 中的图像 2,2
    • Turn the jeans inside out and use pins to attach the patch to cover the hole.
  6. How to Darn a Hole in Denim Jeans by Hand: 步骤 6 中的图像 1,2 How to Darn a Hole in Denim Jeans by Hand: 步骤 6 中的图像 2,2
    • Thread your needle with the thread you chose in Step 3.
    • Cut about 3 feet of your thread and tie a small square knot just big enough to not pull through your fabric.
    • You may need to double, triple, or even quadruple knot the thread to not pull through, depending on the gauge of thread you chose to lose.
  7. How to Darn a Hole in Denim Jeans by Hand: 步骤 7 中的图像 1,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 7 中的图像 2,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 7 中的图像 3,3
    • From the inside insert the needle and pull the thread through completely until the knot is tight against the fabric.
    • Repeat the process by pulling the thread from the outside back to the inside until there is a line formed with your thread.
  8. How to Darn a Hole in Denim Jeans by Hand: 步骤 8 中的图像 1,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 8 中的图像 2,3 How to Darn a Hole in Denim Jeans by Hand: 步骤 8 中的图像 3,3
    • Continue the process shown in Step 7 for the entire perimeter of the patch.
    • Once completed, the patch should be fully attached to the jeans.
  9. How to Darn a Hole in Denim Jeans by Hand: 步骤 9 中的图像 1,1
    • Now that the patch is fully attached, turn the jeans right side out.
    • Insert your needle from the inside of the jeans about 1/2 inch above the top of the hole and 1/2 inch to one side of the hole.
    • Pull the thread tight and insert the needle again on the other side of the hole about 1/2 and inch in the opposite direction.
    • This should create a stitch or a line of thread across the top of the hole.
    • Repeat the process to create enough stitches to cover the entire length of the hole.
  10. How to Darn a Hole in Denim Jeans by Hand: 步骤 10 中的图像 1,2 How to Darn a Hole in Denim Jeans by Hand: 步骤 10 中的图像 2,2
    • Once you have covered the hole completely with thread using lines in one direction, you will weave your needle above and under the stitches you formed in the last step.
    • Begin by putting your needle under the stitch closest and then over the next stitch and under the following, so forth and so on.
    • Continue this process for the entire width of the hole.
    • When you reach your final stitch you will pull your thread tight and begin again from the other direction.
    • Once this is completed, you should insert your needle, pull the thread tight inside the jeans, knot off your thread and cut the excess.
结论
The hole should now be completely repaired and be back to regular function.
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 191
总计 23,952
