跳转到主内容
加入维修社区 - 创建账户
How to Create a Guide
    1. How to Create a Guide, Open User Menu: 步骤 1 中的图像 1,1
      • Click on your username in the top right corner of the site.
      • Select Create A Page from the drop-down menu.
      • If you are already on the category page in which you intend to organize your new guide, you can simply click the Create a Guide button at the top of the page.
      询问修复机器人
      添加评论
    2. How to Create a Guide, Start a New Guide Page: 步骤 2 中的图像 1,3 How to Create a Guide, Start a New Guide Page: 步骤 2 中的图像 2,3 How to Create a Guide, Start a New Guide Page: 步骤 2 中的图像 3,3
      • Select Guide from the Page Options list.
      • Enter the name of the category you'd like to organize your new guide within.
      • If the category already exists, it will appear in a drop-down list below the text box. Select the your category from the list.
      • If the category does not already exist, a new category page will be created.
      • Click Next.
      询问修复机器人
      添加评论
    3. How to Create a Guide, Add Introduction Content: 步骤 3 中的图像 1,1
      • Enter a Title for your new guide.
      • Add a summary to briefly explain what the guide will demonstrate.
      • If you would like to add other information at this time, such as an introduction or flags, click See More.
      • Review the Parts of a Guide Page to better understand the various elements that make up a guide.
      • When finished adding information, click Save.
      询问修复机器人
      添加评论
    4. How to Create a Guide, Create a Step: 步骤 4 中的图像 1,3 How to Create a Guide, Create a Step: 步骤 4 中的图像 2,3 How to Create a Guide, Create a Step: 步骤 4 中的图像 3,3
      • Begin creating the body of your guide by creating your first guide step.
      • Click on the Add a Title text to enter a title for your first step.
      • Click on the Insert wisdom here text to enter your first bullet point text instructions.
      • Use the formatting toolbar at the top of the text editing box to format your text or add links.
      • Use the arrows below the text box indent your bullet. Use the + icon to create a new bullet and the X icon to delete the bullet.
      • Click on the bullet icon itself to change the color or icon for the bullet.
      • Select from the color/icon menu to change your bullet point.
      • Click Save to create your first step!
      询问修复机器人
      添加评论
    5. How to Create a Guide, Keyboard Shortcuts: 步骤 5 中的图像 1,2 How to Create a Guide, Keyboard Shortcuts: 步骤 5 中的图像 2,2
      • Click the keyboard icon at the top of the guide to open a Keyboard Shortcuts pop-up window.
      • Use these (and others listed in the KeyBoard Shortcuts window) to quickly navigate while creating guide steps:
      • Return: Next bullet or insert new bullet.
      • Shift + Return: Previous Bullet or Insert Bullet Above
      • Ctrl + ]: Indent bullet.
      • Ctrl + [: Unindent bullet.
      • Ctrl + D: Delete bullet.
      询问修复机器人
      添加评论
    6. How to Create a Guide, Add Step Visuals: 步骤 6 中的图像 1,3 How to Create a Guide, Add Step Visuals: 步骤 6 中的图像 2,3 How to Create a Guide, Add Step Visuals: 步骤 6 中的图像 3,3
      • Select from either Image or Media to add to your step below the step title.
      • You can add up to three images per step, while video and other media is limited to one file per step.
      • Click the image or media placeholder to open your Media Manager.
      • Click the Add Media button to add a new image or video to your library. Review the Media Manager Help Page for more information about using media.
      • Select the image or media 'file from your library by clicking on it. This will add it to your guide step.
      • If you are using images, you can use the two remaining image placeholders to add up to three images to your step.
      • Click Save to save your visual guide step.
      询问修复机器人
      添加评论
    7. How to Create a Guide, Add Image Markup: 步骤 7 中的图像 1,3 How to Create a Guide, Add Image Markup: 步骤 7 中的图像 2,3 How to Create a Guide, Add Image Markup: 步骤 7 中的图像 3,3
      • Note: Markup cannot be added to videos or other media.
      • Move your curser over your new guide step image, then click the Edit button in the bottom right corner.
      • Select the Markers option from the menu that appears to open the Markup Window.
      • Use the Tool menu at the top left to select a shape, line or arrow marker, then simply click the image where you'd like to add the marker and adjust the size, shape and orientation as needed.
      • Use the Color menu at the top right to select a color for your new marker.
      • Once you've created all desired markers, click the Save Changes button in the very top right corner of the Markup Window.
      • View your new image with the markup and click Save to save it to your guide step.
      询问修复机器人
      添加评论
    8. How to Create a Guide, Add More Steps: 步骤 8 中的图像 1,1
      • Click the + icon in the Step section at the top right corner of the page to add a new step. This option will always add the new step to the end of the guide.
      • You can also use the + Insert Step button to add a new step immediately after the step you're currently editing, rather than at the end of the guide.
      询问修复机器人
      添加评论
    9. How to Create a Guide, Guide Details & Settings: 步骤 9 中的图像 1,1
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 37
总计 1,853
