跳转到主内容
How to Create a Custom Cotton Swab
你所需要的
  1. How to Create a Custom Cotton Swab, Find a tool: 步骤 1 中的图像 1,3 How to Create a Custom Cotton Swab, Find a tool: 步骤 1 中的图像 2,3 How to Create a Custom Cotton Swab, Find a tool: 步骤 1 中的图像 3,3
    • Find a small object with a pointed end, such as:
    • A toothpick
    • A spudger
    • The end of a flossing pick
    • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
  2. How to Create a Custom Cotton Swab, Separate the cotton: 步骤 2 中的图像 1,3 How to Create a Custom Cotton Swab, Separate the cotton: 步骤 2 中的图像 2,3 How to Create a Custom Cotton Swab, Separate the cotton: 步骤 2 中的图像 3,3
    • Pull off a small part of a cotton ball.
    • You only need a small amount of cotton—enough to create a thin layer around your tool.
  3. How to Create a Custom Cotton Swab, Apply the cotton: 步骤 3 中的图像 1,3 How to Create a Custom Cotton Swab, Apply the cotton: 步骤 3 中的图像 2,3 How to Create a Custom Cotton Swab, Apply the cotton: 步骤 3 中的图像 3,3
    • Wrap the cotton around the tip of your tool.
    • Roll the cotton between your fingers to compress it into a thin layer.
  4. How to Create a Custom Cotton Swab, Remove any excess cotton: 步骤 4 中的图像 1,3 How to Create a Custom Cotton Swab, Remove any excess cotton: 步骤 4 中的图像 2,3 How to Create a Custom Cotton Swab, Remove any excess cotton: 步骤 4 中的图像 3,3
    • Test your cotton swab on your device to see if it fits.
    • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
    • If the swab still doesn't fit, you may need to find a different tool altogether.
    • Your custom cotton swab is ready! Return to where you left off in your guide.
结论
For other general electronics skills guides, click here.
27等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,634 声望
创作了1,040篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,652篇指南
1指南评论
My samsung a14 won't charge
Tebogo madibana - 回复
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 170
过去 30 天: 800
总计 12,990
