跳转到主内容
How to Clear RAM on TI-84 Plus CE
  1. How to Clear RAM on TI-84 Plus CE, Open the "MEM" Menu: 步骤 1 中的图像 1,1
    • MEM is the second function of the plus sign, so push 2nd, then the plus sign.
  2. How to Clear RAM on TI-84 Plus CE, Arrow down to "Reset..." and press "Enter": 步骤 2 中的图像 1,1
    • You can also push the "7" key on your calculator
  3. How to Clear RAM on TI-84 Plus CE, Press "Enter": 步骤 3 中的图像 1,2 How to Clear RAM on TI-84 Plus CE, Press "Enter": 步骤 3 中的图像 2,2
    • You can also push the "1" key on your calculator
  4. How to Clear RAM on TI-84 Plus CE, Arrow down to "Reset" and press "Enter": 步骤 4 中的图像 1,2 How to Clear RAM on TI-84 Plus CE, Arrow down to "Reset" and press "Enter": 步骤 4 中的图像 2,2
    • You can also push the "2" key on your calculator
  5. How to Clear RAM on TI-84 Plus CE, Press "Clear" to use your calculator normally again: 步骤 5 中的图像 1,1
    • Congratulations! You are complete!
结论
This is very easy once you get the hang of it. I remember “2nd, Plus Sign, 7, 1, 2”.
4等其他人完成本指南。
Alex Gutowski
于09/15/19注册
412 声望
创作了3篇指南
3指南评论
Will it remove my newly installed apps and games such as Super Mario or Pac-Man?
please answer with dereklytle@student.godleyisd.net
DEREK LYTLE - 回复
Hi Derek,
Yes. The calculator will be restored to factory settings. It will be as if you just purchased the calculator.
Alex Gutowski -
having students clear the ram before a test has been my practice before a test/quiz...but on the TI 84CE if it is low battery and the students try to reset it it just gives a warning of battery too low. Students still have enough 'juice' to use it but I don't ever see the magical words "ram cleared"...do the TI 84CE calculators still clear the ram if it has a very low battery?
Dan Murphy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 83
总计 39,302
