跳转到主内容
How to Clean the Keurig K75 Platinum Brewing System Needle
你所需要的
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: 步骤 1 中的图像 1,1
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: 步骤 2 中的图像 1,1
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: 步骤 3 中的图像 1,1
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
结论
2等其他人完成本指南。
Alexander Vo
于01/11/13注册
94 声望
创作了2篇指南
团队
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G2
4 名成员
创作了6篇指南
9条评论
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - 回复
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - 回复
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - 回复
How about the needle at the bottom of the holder?
tahoejb - 回复
Clean that too. It can’t hurt.
LARRY RODAMMER - 回复
I have used filter water ALL WAYS, in my model B 70 I made a cup this AM. I did not need it on any more so shut it down. Or turn off the power switch. Now that not ready light keep blinking. I done every suggestion on, line. Any help. ????????
jrschex - 回复
where can i get a new silicone gasket
Bill Blogna - 回复
Amazon or ebay
marymckercher -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 27
总计 21,891
