跳转到主内容
How to Clean the Dell MO56UC
你所需要的
  1. How to Clean the Dell MO56UC, Disassembly: 步骤 1 中的图像 1,2 How to Clean the Dell MO56UC, Disassembly: 步骤 1 中的图像 2,2
    • Unplug the USB cord to disconnect the mouse from the power
    • Use a Phillips 00 Screwdriver to unscrew one screw.
  2. How to Clean the Dell MO56UC, Complete mouse disassembly: 步骤 2 中的图像 1,1
    • Take off the top of the mouse.
    • Use a microfiber cloth or a damp towel to remove any debris located inside of the highlighted areas.
  3. How to Clean the Dell MO56UC, Sensors: 步骤 3 中的图像 1,1
    • Twist the ball counter-clockwise to remove it.
    • Clean the ball with a microfiber cloth.
  4. How to Clean the Dell MO56UC, Wipe gently with microfiber cloth: 步骤 4 中的图像 1,1
    • Clean the vertical and horizontal ball sensors with a microfiber cloth.
  5. How to Clean the Dell MO56UC, Examining Wheel: 步骤 5 中的图像 1,1
    • Examine the wheel for debris. The wheel can get dirty frequently which affects performance and may cause issues.
    • Remove any debris found and clean the wheel with a microfiber cloth.
  6. How to Clean the Dell MO56UC, Sensor Error: 步骤 6 中的图像 1,1
    • The wheel clicker sensor is located under the wheel.
  7. How to Clean the Dell MO56UC, Wheel Clicker: 步骤 7 中的图像 1,1
    • Remove the wheel to expose the sensor.
    • Remove any debris and wipe down the sensor with a microfiber cloth.
  8. How to Clean the Dell MO56UC, Plug it back in: 步骤 8 中的图像 1,1
    • Insert the USB Cable back into your computer to supply with power.
    • Test functions of the mouse to insure proper cleaning and reassembly.
  9. How to Clean the Dell MO56UC, If there are still issues, Examine the cord and the USB leads in the male port: 步骤 9 中的图像 1,1
    • Examine the cord for frays or any exposed wire that may cause a bad connection.
结论
4等其他人完成本指南。
团队
Montana Tech, Team 1-4, Shirk Fall 2014 Montana Tech, Team 1-4, Shirk Fall 2014 的会员
MTUM-SHIRK-F14S1G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 70
总计 3,420
