跳转到主内容
How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel
你所需要的
  1. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel, How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the stickers that are hiding the screws.
    • The sticker may or may not stick back on the mouse after you complete the cleaning. You may want to use some clear tape to replace the stickers.
  2. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 2 中的图像 1,1
    • Remove four screws using a Phillips #0 screwdriver.
  3. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 3 中的图像 1,2 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 3 中的图像 2,2
    • Use a spudger to pry along the center seam of the mouse.
    • Open the outer casing of the mouse.
  4. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 4 中的图像 1,1
    • Remove the wires from the white crimp headers in order to separate the upper and lower housing units of the mouse.
    • Pull the wires as gently as possible to ensure that the wires will not break.
  5. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 5 中的图像 1,2 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 步骤 5 中的图像 2,2
    • Take a cotton swab and lightly remove any dirt or debris around the pin connections of the scroll wheel.
结论
5等其他人完成本指南。
Colin
于02/10/14注册
406 声望
创作了3篇指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了16篇指南
1指南评论
You don’t tell how to put the stickers back because they won’t stick again…
p.pisu - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 30
总计 16,519
