跳转到主内容
How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX
你所需要的
  1. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX, How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 1 中的图像 1,1
    • Remove the battery cover and batteries from the remote.
  2. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws on the bottom of the remote.
  3. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 3 中的图像 1,1
    • Insert a spudger into one of the two cavities on the back of the remote.
    • Use the spudger to twist & pry until the seam of the remote separates.
    • Use gentle movements to pry the seam, as if handled improperly can result in damage.
  4. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 4 中的图像 1,1
    • Run a spudger along the seam of the remote to widen the space between the top & bottom halves of the remote.
    • Press firmly into the seam and listen for a popping sound, which indicate the seams have separated.
    • Repeat for both sides of the remote.
    • Return to the back of the remote and use the spudger to pop the remote open.
  5. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 5 中的图像 1,1
    • Remove the rubber number pad and the plastic divider below to reveal the circuit board.
    • Use a cotton swab soaked in rubbing alcohol to clean the exposed circuit board.
    • Try to clean using circular motions. Also, you can clean the affected area directly and not necessarily the whole board.
  6. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 6 中的图像 1,1
    • Clean the rubber number pad by dipping the toothbrush in rubbing alcohol and gently scrubing the back of the rubber keypad.
  7. How to Clean and Maintain a Rogers Champion Plus Universal Remote Control 2125BC0-BX: 步骤 7 中的图像 1,1
    • If you need to replace the circuit board for any reason, it comes off by hand like the other components in this model of remote.
结论
Repeat the steps backwards to reassemble device.
Mohamad Mohamad
于01/18/21注册
436 声望
创作了3篇指南
团队
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 670
