跳转到主内容
How to Clean and Apply Thermal Compound
你所需要的
  1. How to Clean and Apply Thermal Compound, How to Clean and Apply Thermal Compound: 步骤 1 中的图像 1,1
    • Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
    • As the cotton swab becomes saturated with thermal compound, discard and continue with a freshly dipped cotton swab. The compound plate is clean when the cotton swabs come away clean.
  2. How to Clean and Apply Thermal Compound: 步骤 2 中的图像 1,2 How to Clean and Apply Thermal Compound: 步骤 2 中的图像 2,2
    • Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
    • Avoid touching the thermal compound areas once they are clean. Dirt or oil on either surface can disrupt cooling performance and lead to overheating or thermal throttling.
  3. How to Clean and Apply Thermal Compound: 步骤 3 中的图像 1,2 How to Clean and Apply Thermal Compound: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
    • Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
    • You need to clean the thermal plates on both the component and the motherboard, but you only need to apply thermal paste on the motherboard thermal plates.
    • Avoid applying too much or too little thermal compound, as it can impede crucial heat transfer. Once spread, the compound should be about as thick as a single sheet of paper.
  4. How to Clean and Apply Thermal Compound: 步骤 4 中的图像 1,1
    • Gently re-seat your component, making sure that the thermal plates align correctly.
结论
Please refer to the previous guide in order to reassemble your device.
4等其他人完成本指南。
Reina Godeck
于10/16/17注册
741 声望
创作了5篇指南
团队
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 的会员
UWT-LINER-F17S3G5
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 2,616
