跳转到主内容
How to Clean a YardWork LH3185A Snow Blower Carburetor
你所需要的
  1. How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 1 中的图像 1,3 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 1 中的图像 2,3 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 1 中的图像 3,3
    • Block the gas from coming out of the fuel tank using a locking plier.
    • Alternatively, some snowblowers come with a shut-off valve to lock off the gas line.
  2. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 2 中的图像 1,2 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 2 中的图像 2,2
    • Remove the stop key by pulling outwards.
  3. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 3 中的图像 1,1
    • Remove the choke key using a flat screwdriver.
  4. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 4 中的图像 1,2 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 4 中的图像 2,2
    • Remove the two support bolts from the outer shield using an 8 mm socket.
  5. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 5 中的图像 1,1
    • Remove another two support bolts from the outer shield using a Phillips head screwdriver.
  6. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 6 中的图像 1,1
    • Loosen the handlebar by turning the knob counterclockwise until there's enough room to safely remove the shield.
  7. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 7 中的图像 1,2 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 7 中的图像 2,2
    • Remove the inner switch using the 8mm socket.
  8. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 8 中的图像 1,3 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 8 中的图像 2,3 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 8 中的图像 3,3
    • Remove the bolt that holds the reservoir in place using a 13mm socket or spanner.
    • Gas can leak when removing the jet, so have a bucket or towel in place.
  9. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 9 中的图像 1,1
    • Remove the reservoir by pulling downwards.
  10. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 10 中的图像 1,2 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 10 中的图像 2,2
    • Clean the jet nozzle (all three holes) using a pin or small wire.
  11. How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 11 中的图像 1,3 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 11 中的图像 2,3 How to Clean a YardWork LH3185A Snow Blower Carburetor: 步骤 11 中的图像 3,3
    • Clean the inside of the reservoir, the rubber, and the jet using the carburetor cleaner.
    • When reassembling the reservoir, it is crucial to carefully position the rubber component. Improper alignment of the rubber, combined with excessive tightening of the bolt, can result in damaging the rubber seal.
结论
Demitri Roopnarine
于05/28/23注册
293 声望
撰写一个指南
团队
York University, Team A-7, Allen Summer 2023 York University, Team A-7, Allen Summer 2023 的会员
YORK-ALLEN-SU23SAG7
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 287
