跳转到主内容
How to Clean a Samsung DC68 Washing Machine Filter
你所需要的
  1. How to Clean a Samsung DC68 Washing Machine Filter, How to Clean a Samsung DC68 Washing Machine Filter: 步骤 1 中的图像 1,3 How to Clean a Samsung DC68 Washing Machine Filter, How to Clean a Samsung DC68 Washing Machine Filter: 步骤 1 中的图像 2,3 How to Clean a Samsung DC68 Washing Machine Filter, How to Clean a Samsung DC68 Washing Machine Filter: 步骤 1 中的图像 3,3
    • Turn the washing machine off and locate the filter access door.
    • Most Samsung washing machine filters are located at the front. Sometimes they will have a sticker on them to communicate filter cleanliness best practices.
  2. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 2 中的图像 1,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 2 中的图像 2,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 2 中的图像 3,3
    • Gently press the top of the filter door to release and open it.
    • If that doesn't work, use the handle of a small pair of scissors or something similar to push down and open the access door.
  3. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 3 中的图像 1,1
    • Place a rag underneath your access door and place a basin on top.
  4. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 4 中的图像 1,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 4 中的图像 2,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 4 中的图像 3,3
    • Pull out the drain hose and unplug the white cap to let the excess water flow out into the basin.
  5. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 5 中的图像 1,2 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 5 中的图像 2,2
    • Once the water stops coming out from the drain hose, secure it back into position.
  6. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 6 中的图像 1,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 6 中的图像 2,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 6 中的图像 3,3
    • Push the filter in and twist it counterclockwise.
    • Remove the filter from the filter bay.
  7. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 7 中的图像 1,2 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 7 中的图像 2,2
    • Remove any debris from the filter using a paper towel.
    • Rinse the filter under warm water.
  8. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 8 中的图像 1,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 8 中的图像 2,3 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 8 中的图像 3,3
    • Insert the filter back and secure it by twisting it clockwise.
  9. How to Clean a Samsung DC68 Washing Machine Filter: 步骤 9 中的图像 1,2 How to Clean a Samsung DC68 Washing Machine Filter: 步骤 9 中的图像 2,2
    • Close the access door by pushing against the machine until you hear a click sound.
结论
You are all done!
30等其他人完成本指南。
团队
18条评论
Thanks…..
can you share where the filter is located on the
Samsung model DC68-03049A-01.
ampekarek - 回复
Hi! I apologize for the late reply, but I believe the filter for this model would be located inside the spin basket probably at the back. Here is the link to the model description and location of the filter https://www.manualslib.com/manual/147786.... Hope this helps!
Ishmeet Cheema -
It worked! Thank you!
Lisa Cowley - 回复
Hi, thank you for this useful information. How often should the filter be replaced and how to order thank you
Ana Perucho - 回复
I can not get the cap off the drain hose. Any suggestions. I have tried twisting and pulling and it just won't come off
Christine Watkins - 回复
添加评论
浏览统计数据:
过去 24 小时: 111
过去 7 天: 963
过去 30 天: 4,410
总计 110,405
