跳转到主内容
How to Clean a Kitchen Aerator
你所需要的
  1. How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: 步骤 1 中的图像 1,2 How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: 步骤 1 中的图像 2,2
    • Shut off valves that are located under the sink and position faucet in the center to drain remaining water.
  2. How to Clean a Kitchen Aerator: 步骤 2 中的图像 1,1
    • Avoid dropping small parts down the sink by covering the surface of the holes.
  3. How to Clean a Kitchen Aerator: 步骤 3 中的图像 1,1
    • Unscrew and remove aerator with a wrench.
  4. How to Clean a Kitchen Aerator: 步骤 4 中的图像 1,1
    • Clean aerator by soaking it in white vinegar overnight in a bowl or cup.
  5. How to Clean a Kitchen Aerator: 步骤 5 中的图像 1,1
    • Dry off aerator with a towel.
  6. How to Clean a Kitchen Aerator: 步骤 6 中的图像 1,1
    • Use a wrench to screw back on the aerator to the faucet.
  7. How to Clean a Kitchen Aerator: 步骤 7 中的图像 1,1
    • Slowly turn back on water valves to check for improves water pressure.
    • Make sure sink is cleared and components of faucet that were removed are sealed tight.
结论
Amber Cuddon
于01/20/18注册
154 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 922
