跳转到主内容
加入维修社区 - 创建账户
How to Clean a Flat Iron
你所需要的
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: 步骤 1 中的图像 1,1
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: 步骤 2 中的图像 1,2 How to Clean a Flat Iron: 步骤 2 中的图像 2,2
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: 步骤 3 中的图像 1,2 How to Clean a Flat Iron: 步骤 3 中的图像 2,2
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: 步骤 5 中的图像 1,2 How to Clean a Flat Iron: 步骤 5 中的图像 2,2
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: 步骤 6 中的图像 1,2 How to Clean a Flat Iron: 步骤 6 中的图像 2,2
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: 步骤 7 中的图像 1,1
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: 步骤 8 中的图像 1,1
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: 步骤 9 中的图像 1,1
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
结论
Congratulations your flat iron is buildup free!
3等其他人完成本指南。
Jacquelin
于02/23/15注册
283 声望
撰写一个指南
团队
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 的会员
CPSU-GREEN-W15S12G2
6 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 63
总计 6,584
