跳转到主内容
How to Clean a Filter on a MAYTAG Laundry Machine
你所需要的
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 1 中的图像 1,3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 1 中的图像 2,3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 1 中的图像 3,3
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 2 中的图像 1,3 How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 2 中的图像 2,3 How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 2 中的图像 3,3
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 3 中的图像 1,1
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 4 中的图像 1,3 How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 4 中的图像 2,3 How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 4 中的图像 3,3
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: 步骤 5 中的图像 1,1
    • Screw the filter clockwise back into place.
终点
另外一个人完成了本指南。
Kaelyn Taing
于10/26/22注册
151 声望
撰写一个指南
团队
CSU Los Angeles, Team 50-50, Briggs Fall 2022 CSU Los Angeles, Team 50-50, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S50G50
1 名成员
创作了2篇指南
一条评论
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 66
过去 30 天: 365
总计 7,974
