跳转到主内容
简介
Here I am going to show you how to clean up solder from two points on a logic board.In this case I am working on a chinese A13 all winner tablet and I am cleaning the solder points for the battery so I can correctly install a new battery on the logic boar
  1. The materials needed for this are a soldering iron, soldering paste and desoldering wire, also known as a wick.
    • The materials needed for this are a soldering iron, soldering paste and desoldering wire, also known as a wick.
  2. There are many types of soldering paste many of which are in a syringe like tube which makes it easy to get the paste in the exact spot it needs to be.
    • There are many types of soldering paste many of which are in a syringe like tube which makes it easy to get the paste in the exact spot it needs to be.
    • I personally use a plastic opening tool to scoop a little out and apply it gently on the spot I will be working on.
  3. The location I will be de-soldering is right above the SPK location in the photo.
    • The location I will be de-soldering is right above the SPK location in the photo.
  4. Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder. Please remember that logic board components are very fragile and excessive heat can destroy these components.
    • Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
    • Please remember that logic board components are very fragile and excessive heat can destroy these components.
    • Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
  5. What’s left over is clean points on the solder board, ready for fresh solder.
    • What’s left over is clean points on the solder board, ready for fresh solder.
终点
66等其他人完成本指南。
Romin
于2013年04月29日注册
3,528 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 26
过去的30天: 129
总计 10,037
