跳转到主内容
加入维修社区 - 创建账户
How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller
浏览量: 1.7万
浏览统计数据:
过去24小时
49
过去 7 天:
276
过去 30 天:
1,088
总计
17,074
评论: 1
1 guide comment.
Go to guide comments
已完成: 11
11 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 20 - 25 分钟
难度: 中等
When playing games on the PS4 the controller is one of the most important devices that need to be working properly for a smooth experience. Having broken or gummed up buttons can be very frustrating when trying to play games on the PS4.
This is a guide on how to clean the R2 and L2 buttons on the DualShock 4 PS4 controller. If you are having issues with the L2 and R2 buttons not working properly, for example, the button trigger is not fully pressing down or it is not registering properly, this guide will solve that problem.
This guide will show the process of dissembling the controller and the removal of the L2 and R2 buttons and showing how to clean them.
你所需要的
工具
    1. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 步骤 1 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 步骤 1 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove the four 6.0 mm screws located on the back of the controller.
      询问修复机器人
      添加评论
    2. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 3,3
      • Separate the front and the back of the controller by pulling both pieces apart at the same time.
      • Be very careful and gentle when pulling the shells apart because the blue ribbon can become detached and damaged.
      询问修复机器人
      添加评论
    3. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 3 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 3 中的图像 2,2
      • Carefully unplug the blue ribbon from the body of the controller shell.
      询问修复机器人
      添加评论
    4. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 3,3
      • Remove the left and right triggers by wiggling the buttons sideways until they are completely off.
      询问修复机器人
      添加评论
    5. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 5 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 5 中的图像 2,2
      • Take the Q-tip and soak it into the isopropyl alcohol.
      • Clean around the trigger button area as well as under and above the rubber padding.
      询问修复机器人
      添加评论
    6. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 3,3
      • Put the L2 and R2 buttons back into place by simply forcing them into position until properly locked.
      询问修复机器人
      添加评论
    7. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 7 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 7 中的图像 2,2
      • Attach the blue ribbon back into its original location so that the two shells of the controller are connected.
      询问修复机器人
      添加评论
    8. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 8 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 8 中的图像 2,2
      • Put the two shells of the controller together by pushing them together at the same time.
      询问修复机器人
      添加评论
    9. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 3,3
      • Screw the four 6.0mm screws on the back of the controller using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
11等其他人完成本指南。
作者
与
Joseph Cao
于09/14/23注册
475 声望
撰写一个指南
团队
York University, Team 2-5, O'Regan Fall 2023 York University, Team 2-5, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G5
1 名成员
创作了12篇指南
1指南评论
سلام اون نظری که واستون گذاشتم رسید به دستتون گفتم اگر نشه درست نشه باید چیکار کنیم
ایمان هاشمی - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 49
过去 7 天: 276
过去 30 天: 1,088
总计 17,074
