跳转到主内容
How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller
你所需要的
  1. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 步骤 1 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 6.0 mm screws located on the back of the controller.
  2. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 2 中的图像 3,3
    • Separate the front and the back of the controller by pulling both pieces apart at the same time.
    • Be very careful and gentle when pulling the shells apart because the blue ribbon can become detached and damaged.
  3. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 3 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 3 中的图像 2,2
    • Carefully unplug the blue ribbon from the body of the controller shell.
  4. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 4 中的图像 3,3
    • Remove the left and right triggers by wiggling the buttons sideways until they are completely off.
  5. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 5 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 5 中的图像 2,2
    • Take the Q-tip and soak it into the isopropyl alcohol.
    • Clean around the trigger button area as well as under and above the rubber padding.
  6. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 6 中的图像 3,3
    • Put the L2 and R2 buttons back into place by simply forcing them into position until properly locked.
  7. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 7 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 7 中的图像 2,2
    • Attach the blue ribbon back into its original location so that the two shells of the controller are connected.
  8. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 8 中的图像 1,2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 8 中的图像 2,2
    • Put the two shells of the controller together by pushing them together at the same time.
  9. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 1,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 2,3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 步骤 9 中的图像 3,3
    • Screw the four 6.0mm screws on the back of the controller using the Phillips #00 screwdriver.
终点
另外一个人完成了本指南。
Joseph Cao
于09/14/23注册
196 声望
撰写一个指南
团队
York University, Team 2-5, O'Regan Fall 2023 York University, Team 2-5, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G5
1 名成员
创作了2篇指南
一条评论
سلام اون نظری که واستون گذاشتم رسید به دستتون گفتم اگر نشه درست نشه باید چیکار کنیم
ایمان هاشمی - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 87
过去 30 天: 340
总计 2,212
