跳转到主内容
加入维修社区 - 创建账户
How to Clean The Exit Needle of the Keurig B60
你所需要的
  1. How to Clean The Exit Needle of the Keurig B60, How to Clean The Exit Needle of the Keurig B60: 步骤 1 中的图像 1,1
    • Lift Handle to open Lid
  2. How to Clean The Exit Needle of the Keurig B60: 步骤 2 中的图像 1,3 How to Clean The Exit Needle of the Keurig B60: 步骤 2 中的图像 2,3 How to Clean The Exit Needle of the Keurig B60: 步骤 2 中的图像 3,3
    • Remove K-Cup Pack Holder Assembly by pinching the left and right sides to release clamp. Wiggle slightly to remove
  3. How to Clean The Exit Needle of the Keurig B60: 步骤 3 中的图像 1,3 How to Clean The Exit Needle of the Keurig B60: 步骤 3 中的图像 2,3 How to Clean The Exit Needle of the Keurig B60: 步骤 3 中的图像 3,3
    • Pull and snap apart the funnel from the K-Cup Pack Holder (If this is the first time separating the Pack Holder Assembly, more force may be required)
  4. How to Clean The Exit Needle of the Keurig B60: 步骤 4 中的图像 1,2 How to Clean The Exit Needle of the Keurig B60: 步骤 4 中的图像 2,2
    • Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
    • Flip K-Cup Pack Holder and repeat
  5. How to Clean The Exit Needle of the Keurig B60: 步骤 5 中的图像 1,2 How to Clean The Exit Needle of the Keurig B60: 步骤 5 中的图像 2,2
    • With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
结论
Once reassembled, run the brewer once or twice with just water to cleanse the system.
10等其他人完成本指南。
Jake Wynn
于04/11/16注册
836 声望
创作了5篇指南
团队
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G7
5 名成员
创作了10篇指南
2指南评论
I used the needle but it fell into the area.  How do I get the needle out?
pspicuzza - 回复 分享
The bottom needle is loose on small piece of plastic is this normal or broke?
confused40 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 116
总计 28,489
