跳转到主内容
How to Clean SteelSeries Apex Pro Gaming Keyboard
你所需要的
  1. How to Clean SteelSeries Apex Pro Gaming Keyboard, How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 1 中的图像 1,1
    • Place the keyboard down on a flat surface and disconnect from any power source.
  2. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 2 中的图像 1,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 2 中的图像 2,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 2 中的图像 3,3
    • Pour some isopropyl alcohol into a paper towel.
    • Use the same paper towel to clean the keyboard and the keyboard rest pad.
  3. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 3 中的图像 1,2 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 3 中的图像 2,2
    • Use your index finger and thumb to remove each key cap starting from left to right.
    • Remove the smaller key caps first so the surrounding larger key caps can be removed easier.
    • Place each key cap that was removed from the keyboard on a flat surface in order from left to right.
  4. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 4 中的图像 1,2 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 4 中的图像 2,2
    • Use a can of compressed air to remove all the dust from the keyboard.
  5. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 5 中的图像 1,2 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 5 中的图像 2,2
    • Dip a cotton swab into the isopropyl alcohol bottle.
    • Use the cotton swab to clean tight spots on the keyboard.
  6. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 6 中的图像 1,2 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 6 中的图像 2,2
    • Dip another cotton swab in the isopropyl alcohol.
    • Use the cotton swab to clean the inside and outside of every key switch.
  7. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 7 中的图像 1,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 7 中的图像 2,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 7 中的图像 3,3
    • Use your index finger and thumb to place the keycaps on the keyboard, starting from the top to the bottom.
  8. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 8 中的图像 1,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 8 中的图像 2,3 How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 8 中的图像 3,3
    • Use the paper towel to clean the keyboard, keyboard rest bar, and the keyboard's cable.
  9. How to Clean SteelSeries Apex Pro Gaming Keyboard: 步骤 9 中的图像 1,1
    • Make sure all keycaps are placed in the right place and functioning properly.
结论
Congratulations, your SteelSeries Apex Pro keyboard is clean! Repeat these steps every once in a while as needed to keep your keyboard clean and extend the life of your keyboard.
Luis Espinosa
于01/24/22注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team 8-1, Briggs Spring 2022 CSU Los Angeles, Team 8-1, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S8G1
2 名成员
创作了2篇指南
2指南评论
Je pense qu'utiliser de l'acool isopropylique est une c...erie
Guynemer - 回复
Pourquoi ? Argumentes.
Parce que ça désinfecte, nettoie en profondeur les touches sans risque de voir les caractères s'effacer ? (sauf clavier leader price bien sûr)
Valurion -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 96
总计 8,125
