跳转到主内容
How to Clean Stains On A Baking Sheet
你所需要的
  1. How to Clean Stains On A Baking Sheet, How to Clean Stains On A Baking Sheet: 步骤 1 中的图像 1,1
    • Place the dirty baking sheet on a flat surface.
    • Tip: This method can be used on stained pots and pans as well.
    • Tip: This method works best if you clean the stained baking sheet as soon as it has cooled after use.
    • Note: The liquid on the baking sheet is grease. This method will work whether or not there is grease on the baking sheet
  2. How to Clean Stains On A Baking Sheet: 步骤 2 中的图像 1,2 How to Clean Stains On A Baking Sheet: 步骤 2 中的图像 2,2
    • Cover the stained part of the baking sheet with a thin layer of baking soda.
  3. How to Clean Stains On A Baking Sheet: 步骤 3 中的图像 1,2 How to Clean Stains On A Baking Sheet: 步骤 3 中的图像 2,2
    • Pour a small amount of water over the baking soda so the baking soda looks pasty.
    • Tip: Do not put too much water on the baking soda, as it will cause the baking soda to spread and not stay on the desired cleaning area.
  4. How to Clean Stains On A Baking Sheet: 步骤 4 中的图像 1,1
    • Set a timer for 15 minutes, press start, and wait until timer goes off.
  5. How to Clean Stains On A Baking Sheet: 步骤 5 中的图像 1,2 How to Clean Stains On A Baking Sheet: 步骤 5 中的图像 2,2
    • Take a sponge and clean the desired area.
    • Tip: If the baking soda becomes too thick when scrubbing, add more water.
    • Tip: Using the rough side of the sponge makes cleaning easier.
  6. How to Clean Stains On A Baking Sheet: 步骤 6 中的图像 1,3 How to Clean Stains On A Baking Sheet: 步骤 6 中的图像 2,3 How to Clean Stains On A Baking Sheet: 步骤 6 中的图像 3,3
    • Rinse off the baking soda and wash the baking sheet again with soap and water.
结论
Congratulations! You have a baking sheet that looks good as new.
31等其他人完成本指南。
Ashlee Takushi
于02/24/15注册
1,129 声望
撰写一个指南
团队
Cal Poly, Team 23-5, Green Winter 2015 Cal Poly, Team 23-5, Green Winter 2015 的会员
CPSU-GREEN-W15S23G5
4 名成员
创作了9篇指南
3指南评论
I’ve also had good success getting stains off stainless steel following a similar process but using cream of tartar + vinegar instead of baking soda + water. Cream of tartar with vinegar forms an acidic paste instead of the alkaline paste of the baking soda. Of course, don’t mix these approaches or expect unhelpful frothiness.
Don - 回复
Don, thanks for the additional tips, especially the acidic versus alkaline aspects.
Mike Rehbein -
is that a non stick baking sheet? How is it on steel?
Christine Shriam - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 92
总计 9,650
