跳转到主内容
How to Clean Nintendo Entertainment System Cartridges
你所需要的
  1. How to Clean Nintendo Entertainment System Cartridges, Take Apart the Cartridge: 步骤 1 中的图像 1,1
    • Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
  2. How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 步骤 2 中的图像 1,2 How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 步骤 2 中的图像 2,2
    • Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
  3. How to Clean Nintendo Entertainment System Cartridges, Scrub the Contacts: 步骤 3 中的图像 1,1
    • Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
    • After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
结论
And with that your cartridge should be working properly!
3等其他人完成本指南。
[deleted]
于06/12/22注册
569 声望
创作了2篇指南
4指南评论
Is this a joke?
Mizuho Chan - 回复
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
Randall Mattoon -
In my opinion, a less abrasive metal polish would probably be better to start with.
Jeff Griffith - 回复
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
mwbarnhart - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 103
总计 5,005
