跳转到主内容
加入维修社区 - 创建账户
How to Clean Corroded Battery Terminals
你所需要的
    1. How to Clean Corroded Battery Terminals, Safety precautions: 步骤 1 中的图像 1,1
      • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
      • If your device still works, power it down completely before starting.
      添加评论
    2. How to Clean Corroded Battery Terminals, Remove the batteries: 步骤 2 中的图像 1,3 How to Clean Corroded Battery Terminals, Remove the batteries: 步骤 2 中的图像 2,3 How to Clean Corroded Battery Terminals, Remove the batteries: 步骤 2 中的图像 3,3
      • Remove the batteries from your device.
      • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
      • If any batteries are stuck, follow the next step as normal to clean around them.
      询问修复机器人
      添加评论
    3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 步骤 3 中的图像 1,3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 步骤 3 中的图像 2,3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      Anti-Static Brush
      $2.99
      • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
      • Use the point of a spudger to pick out any bits that are stuck.
      • Pick around the batteries, and not at the batteries themselves.
      • Flip your device over and gently shake out the loose corrosion and debris.
      • Dispose of the corrosion and debris in the trash.
      添加评论
    4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: 步骤 4 中的图像 1,2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: 步骤 4 中的图像 2,2
      • You should now be able to remove any batteries that were previously stuck.
      • Clean out the battery recess with a toothbrush.
      添加评论
    5. How to Clean Corroded Battery Terminals, Clean the terminals: 步骤 5 中的图像 1,3 How to Clean Corroded Battery Terminals, Clean the terminals: 步骤 5 中的图像 2,3 How to Clean Corroded Battery Terminals, Clean the terminals: 步骤 5 中的图像 3,3
      • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
      • Lightly dip a cotton swab in white vinegar or lemon juice.
      • Don't soak the cotton swab. Only use a small amount of liquid at a time.
      • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
      • The corrosion may fizz and bubble. Don't worry, this is normal.
      • Continue this process until there's no corrosion on the terminals.
      询问修复机器人
      添加评论
    6. How to Clean Corroded Battery Terminals: 步骤 6 中的图像 1,3 How to Clean Corroded Battery Terminals: 步骤 6 中的图像 2,3 How to Clean Corroded Battery Terminals: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Microfiber Cleaning Cloths
      $3.99
      • Isopropyl alcohol will remove any residue left from the previous step.
      • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
      • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
      • Wipe the residue away with a microfiber or lint-free cloth.
      • Repeat this process until the terminals are completely clean.
      • Wait two minutes to allow any residual alcohol to evaporate.
      询问修复机器人
      添加评论
    7. How to Clean Corroded Battery Terminals, Install new batteries: 步骤 7 中的图像 1,3 How to Clean Corroded Battery Terminals, Install new batteries: 步骤 7 中的图像 2,3 How to Clean Corroded Battery Terminals, Install new batteries: 步骤 7 中的图像 3,3
      添加评论
结论
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
取消:我没有完成这个指南。
21等其他人完成本指南。
Spencer Day
于09/14/22注册
199,886 声望
创作了1,243篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了79,518篇指南
2指南评论
Good article, thanks.
MarkDownUnder - 回复 分享
Nice Article . Thanks Bro
TSM Tool - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 52
过去 7 天: 429
过去 30 天: 2,090
总计 72,459
