跳转到主内容
How to Clean Canon PIXMA MP190 Print Head Nozzle
  1. How to Clean Canon PIXMA MP190 Print Head Nozzle, Turn printer on.: 步骤 1 中的图像 1,1
    • The printer needs to be on in order to change the ink cartridges.
  2. How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 步骤 2 中的图像 1,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 步骤 2 中的图像 2,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Locate Ink Cartridges: 步骤 2 中的图像 3,3
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 步骤 3 中的图像 1,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 步骤 3 中的图像 2,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Remove Ink Cartridge: 步骤 3 中的图像 3,3
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
  4. How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 步骤 4 中的图像 1,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 步骤 4 中的图像 2,3 How to Clean Canon PIXMA MP190 Print Head Nozzle, Clean Ink Nozzle: 步骤 4 中的图像 3,3
    • Hold the ink cartridge with the ink nozzle facing up. Using a paper towel firmly wipe the entire ink nozzle.
    • Repeat until the nozzle appears free of any ink and debris.
结论
另外一个人完成了本指南。
Garret Wescott
于10/23/14注册
597 声望
创作了4篇指南
团队
Michigan Tech, Team 1-5, Lauer Fall 2014 Michigan Tech, Team 1-5, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G5
3 名成员
创作了5篇指南
一条评论
is ther an easy way to gain access to the roller at the rear of the machine to clean it
hope342 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 5,569
