跳转到主内容
How to Clean Calcium Deposits From a Sprinkler Head
你所需要的
  1. How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: 步骤 1 中的图像 1,2 How to Clean Calcium Deposits From a Sprinkler Head, How to Clean Calcium Deposits From a Sprinkler Head: 步骤 1 中的图像 2,2
    • Place your fingers under the edges of the smaller circle, then slowly lift the head.
    • Keep a hose close by to make it easier to clean the basket.
  2. How to Clean Calcium Deposits From a Sprinkler Head: 步骤 2 中的图像 1,2 How to Clean Calcium Deposits From a Sprinkler Head: 步骤 2 中的图像 2,2
    • Twist the head counter clockwise to remove the sprinkler head from the neck, exposing the basket.
  3. How to Clean Calcium Deposits From a Sprinkler Head: 步骤 3 中的图像 1,2 How to Clean Calcium Deposits From a Sprinkler Head: 步骤 3 中的图像 2,2
    • If working with two people, use one hand to hold the base of the neck so the sprinkler doesn't fall back into the body of the sprinkler.
    • If working by yourself, slowly release the neck back down. It is still retrievable by twisting the head back on and repeating the process in step 2.
  4. How to Clean Calcium Deposits From a Sprinkler Head: 步骤 4 中的图像 1,1
    • Use the hose to wash out the basket of any dirt or calcium deposits.
  5. How to Clean Calcium Deposits From a Sprinkler Head: 步骤 5 中的图像 1,1
    • Reassemble the head, placing back the basket in the center of the neck and twisting the head clockwise to tighten it down.
  6. How to Clean Calcium Deposits From a Sprinkler Head: 步骤 6 中的图像 1,1
    • Release the neck and the sprinkler is clean and ready for use.
结论
Once the head is reassembled the water flow should no longer be obstructed and should regain the full range of spray.
Max Warrick
于07/03/23注册
133 声望
撰写一个指南
团队
一条评论
question: What is the flathead screw in the center of the sprinkler head for?
David Franco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 203
