跳转到主内容
加入维修社区 - 创建账户
How to Check a Car's Tire Pressure
你所需要的
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 步骤 1 中的图像 1,2 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: 步骤 1 中的图像 2,2
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
    询问修复机器人
    添加评论
  2. How to Check a Car's Tire Pressure: 步骤 2 中的图像 1,3 How to Check a Car's Tire Pressure: 步骤 2 中的图像 2,3 How to Check a Car's Tire Pressure: 步骤 2 中的图像 3,3
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
    询问修复机器人
    添加评论
  3. How to Check a Car's Tire Pressure: 步骤 3 中的图像 1,2 How to Check a Car's Tire Pressure: 步骤 3 中的图像 2,2
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
    询问修复机器人
    添加评论
  4. How to Check a Car's Tire Pressure: 步骤 4 中的图像 1,2 How to Check a Car's Tire Pressure: 步骤 4 中的图像 2,2
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
Craig Lloyd
于02/10/16注册
42,948 声望
创作了82篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 24
过去 30 天: 117
总计 4,115
