跳转到主内容
加入维修社区 - 创建账户
How to Check Resistance of Suzuki Wagon R Temperature Sensor
你所需要的
    • Be careful when working on Engine! Dont test when engine is running. Wait for engine to cool down!!
    询问修复机器人
    添加评论
  1. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: 步骤 2 中的图像 1,2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Open the Bonnet to access Engine Compartment: 步骤 2 中的图像 2,2
    • Pull the bonnet release handle located on the outboard side of the driver's side of the instrument panel. This will disengage the bonnet lock halfway
    • Push the under-bonnet release lever sideways with your finger. While pushing the lever, lift up the bonnet
    • Continue to lift up the bonnet until it is high enough to support with the prop rod
    • Make sure the bonnet is fully closed and latched before driving. If it is not,it can fly up unexpectedly during driving, obstructing your view and resulting in an accident.
    询问修复机器人
    添加评论
  2. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: 步骤 3 中的图像 1,2 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Unplug the Plug connection: 步骤 3 中的图像 2,2
    • The component Intake air temperature sensor is located in the intake pipe just after the Air Filter.
    • Unplug the plug connection by pressing the release tab
    询问修复机器人
    添加评论
  3. How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: 步骤 4 中的图像 1,3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: 步骤 4 中的图像 2,3 How to Check Resistance of Suzuki Wagon R Temperature Sensor, Measure Resistance: 步骤 4 中的图像 3,3
    • Turn the knob in the multimeter to set the test to Ohms/Resistance
    • Connect the terminal 1 and 2 of the component Intake air temperature sensor to Multimeter positive and negative
    • The set value at ignition on and engine cold is 1.3KOhms
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
ananda
于03/18/15注册
238 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 88
总计 6,390
