跳转到主内容
How to Change an Indoor Doorknob Handle
你所需要的
  1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: 步骤 1 中的图像 1,1
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. How to Change an Indoor Doorknob Handle: 步骤 2 中的图像 1,1
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. How to Change an Indoor Doorknob Handle: 步骤 3 中的图像 1,1
    • Unscrew both long screws.
  4. How to Change an Indoor Doorknob Handle: 步骤 4 中的图像 1,1
    • Remove the door knob on both sides of the door.
  5. How to Change an Indoor Doorknob Handle: 步骤 5 中的图像 1,1
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. How to Change an Indoor Doorknob Handle: 步骤 6 中的图像 1,1
    • Unscrew the two short screws on the latch face plate.
  7. How to Change an Indoor Doorknob Handle: 步骤 7 中的图像 1,1
    • Remove the latch face plate and latch mechanism.
  8. How to Change an Indoor Doorknob Handle: 步骤 8 中的图像 1,1
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. How to Change an Indoor Doorknob Handle: 步骤 9 中的图像 1,1
    • Screw in both short screws of the latch face plate.
  10. How to Change an Indoor Doorknob Handle: 步骤 10 中的图像 1,1
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. How to Change an Indoor Doorknob Handle: 步骤 11 中的图像 1,1
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. How to Change an Indoor Doorknob Handle: 步骤 12 中的图像 1,1
    • Screw in both long screws on both sides of the door knob.
  13. How to Change an Indoor Doorknob Handle: 步骤 13 中的图像 1,1
    • Turn the door knob to test your work.
结论
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
6等其他人完成本指南。
Mallory
于02/19/15注册
220 声望
撰写一个指南
团队
CSU Stanislaus, Team 1-1, Moberly Spring 2015 CSU Stanislaus, Team 1-1, Moberly Spring 2015 的会员
CSUS-MOBERLY-S15S1G1
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 50
总计 9,279
