本指南有最近更改,您可查看未经巡查的最新版本。
简介
The most often neglected fluid and filter on the W123 cars is the power steering fluid and power steering filter.
Learn to change yours today, and extend the life of your pump and steering gear box.
你所需要的
Jack up the front of the car so you can turn the steering wheel while the car is stationary.
See the guide on jacking up your car, if you need guidance on this.
To start the process of changing your power steering fluid, you'll need to remove the lid on the pump reservoir.
If you want guidance on this, and on checking the fluid level, see the guide on checking power steering fluid level.
Replace the spring, retainer and nut over the filter and tighten down. The spring should still have some room to expand and contract but should be snug.
Fill the reservoir to the bottom of the metal rim around the top of the pump housing.
This car is getting power steering fluid, instead of automatic transmission fluid. Both are OK. The power steering fluid is clear.
Now, turn on the engine. Be sure the car is in park or neutral first. Turn the steering wheel left and right, as far as it will go, a few times to get out any air.
Top off the fluid as needed. Never let the pump run dry.
If your fluid is very dirty, simply repeat the process of sucking out fluid, putting the filter back in, filling the reservoir, and then running the engine and turning the wheel until it looks clean.
Finish by re-installing the cap and taking it for a test drive.
21等其他人完成本指南。
14条评论
I find this tutorial so simple to follow. I prefer images and text to video. Well done!!!
Holden, I am glad it was helpful! I agree, I usually prefer good pictures and text to a video - no need to rewind when you miss something.
Agreed. Very well done !
Thank you so much for your detailed guides! What sort of symptoms could we expect if the power steering fluid or filter need replacing?
This was so professional; technical writers take notice!
