跳转到主内容
How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: 步骤 1 中的图像 1,2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: 步骤 1 中的图像 2,2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: 步骤 2 中的图像 1,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 2 中的图像 2,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 2 中的图像 3,3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: 步骤 3 中的图像 1,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 3 中的图像 2,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 3 中的图像 3,3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: 步骤 4 中的图像 1,2 How to Change Broken Buttons on your Lexus Key Fob: 步骤 4 中的图像 2,2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: 步骤 5 中的图像 1,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 5 中的图像 2,3 How to Change Broken Buttons on your Lexus Key Fob: 步骤 5 中的图像 3,3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
结论
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7等其他人完成本指南。
Michael Tan
于01/08/15注册
587 声望
创作了3篇指南
团队
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 的会员
CPSU-GREEN-S15S30G3
4 名成员
创作了10篇指南
一条评论
useless guide
Davide - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 41
总计 6,103
