跳转到主内容
How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone
你所需要的
  1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: 步骤 1 中的图像 1,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: 步骤 1 中的图像 2,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: 步骤 1 中的图像 3,3
    • Swipe up from the bottom of the home screen and open the Device Help app.
    • If you don't see the app, use the search bar at the top of the screen.
  2. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Check your app version: 步骤 2 中的图像 1,2 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Check your app version: 步骤 2 中的图像 2,2
    • Click the three dots in the top right corner () and select About.
    • Check that your App Version is 12.6.1 or greater. If it's not, go to Google Play and update the Device Help app.
    • Return to the main page of the Device Help app.
  3. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: 步骤 3 中的图像 1,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: 步骤 3 中的图像 2,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: 步骤 3 中的图像 3,3
    • Click the three dots in the top right corner () again and select Calibrate sensor.
    • Click Continue twice in the bottom right corner, reading through the information on screen.
  4. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibration information: 步骤 4 中的图像 1,2 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibration information: 步骤 4 中的图像 2,2
    • Before starting the calibration, make sure your screen is clean and free of any dust or grime.
    • Check the three calibration blocks and ensure they're clean and undamaged.
    • You should have two blocks with indents, and a third block with small grooves on one side (which you should be able to feel). The grooved block may be smaller than the other two.
  5. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: 步骤 5 中的图像 1,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: 步骤 5 中的图像 2,3 How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: 步骤 5 中的图像 3,3
    • Click Start in the top left corner and follow the instructions on screen to complete the calibration.
    • During calibration, note the following:
    • Make sure the blocks are aligned with and covering the red square on your screen.
    • You only need to press gently on the blocks. Don't compress them.
    • During Step 3, make sure the grooves on the bottom of the block are oriented correctly, as described in the on-screen instructions.
结论
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration failed for any reason, repeat the calibration procedure.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
61,610 声望
创作了445篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,058篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 113
过去 30 天: 430
总计 5,785
