跳转到主内容
加入维修社区 - 创建账户
How to Build and Use a Test Cord for Appliance Testing
视频指南
本指南转录自 YouTube 视频。
你所需要的
    • Work on a dry, non-conductive surface with the appliance part secured so it can’t roll, spin, or move when powered.
    • WARNING: This procedure uses live mains voltage, which can cause shock, burns, or death.
    • Unplug the test cord any time you’re attaching wires or changing configurations.
    • Keep fingers, tools, jewelry, and loose clothing away from exposed terminals and moving parts.
    • Use a GFCI-protected outlet if possible, and don’t test parts near water.
    询问修复机器人
    添加评论
    • Get a basic two-prong lamp cord with an inline on/off switch.
    • Get 14 AWG female spade terminals that match the tabs on the parts you plan to test.
    • Get a kilowatt meter if you want to measure watts, volts, and amps while testing.
    • Use a quality crimping tool, since low-quality crimp connectors can fail and waste time and money.
    • Use a wire stripper or cutter as needed for your cord and terminals.
    询问修复机器人
    添加评论
    • Open the cord end you’ll be adding connectors to, so the two conductors are accessible.
    • Strip enough insulation from each conductor to fit fully into the spade terminal barrel you’re using.
    • Twist the exposed wire strands on each conductor so they’re tight and secure.
    • Caution: Don’t leave stray strands outside the terminal, since they can short to the other wire or to metal parts.
    询问修复机器人
    添加评论
    • Slide a 14 AWG female spade terminal onto a prepared wire end until the copper is fully inside the barrel.
    • Use the blue crimp position on the crimping tool for these 14 AWG terminals.
    • Crimp the terminal firmly, then pull on the wire to confirm it won’t slip out.
    • Repeat the strip, twist, and crimp process for the second conductor.
    • A test cord is a good place to practice crimping, since a bad crimp can cause poor contact and unsafe heating.
    询问修复机器人
    添加评论
    • Plug the kilowatt meter into the wall outlet.
    • Plug the cheater cord into the kilowatt meter, and set the cord’s switch to Off.
    • Use the meter to view watts and other readings while the part is running.
    • Caution: Treat the spade terminals as live whenever the cord is plugged in, even if the switch is Off.
    询问修复机器人
    添加评论
    • Attach the two female spade terminals to the drain pump’s two terminals.
    • Identify which pump wire is live and which is neutral before powering the pump.
    • In this configuration, the live is on the blue wire and the neutral is on the brown wire.
    • Turn the cord’s switch On to run the pump and read the wattage on the kilowatt meter.
    • If you suspect polarity affects the pump’s rotation, shut the switch Off, unplug the cord, swap the connections, and test again.
    • Caution: Don’t intentionally jam or obstruct a running pump with tools, since you can damage the part and seriously injure yourself.
    询问修复机器人
    添加评论
    • Connect the cheater cord’s spade terminals to the heater wiring using the existing piggyback connectors so the terminals can be swapped quickly.
    • Turn the cord’s switch On and watch the kilowatt meter to see the heater’s power draw.
    • Carefully feel for heat at a safe distance and verify the element is warming.
    • Caution: Heater elements get hot enough to burn skin and ignite nearby materials, so keep the element away from plastic, paper, and wiring insulation.
    • In this test, the meter showed about 13.4 to 13.5 watts, and the heater produced a noticeable temperature increase.
    询问修复机器人
    添加评论
    • Switch the cord Off and confirm the meter drops to zero watts before handling any connections.
    • Unplug the cord from the meter, then unplug the meter from the wall outlet.
    • Inspect each crimp for a tight fit, since poor-quality crimp terminals can fail and cause unreliable tests.
    • Build multiple cords if you want different end connectors, such as versions with male connectors for plug-in style connections.
    • Reminder: Store the cheater cord with the switch set to Off so it’s less likely to be energized accidentally during setup.
    询问修复机器人
    添加评论
结论
Use the cheater cord and kilowatt meter to verify that a component runs, heats, or draws power in a way that matches expectations. Keep tests short, keep terminals covered and away from contact, and unplug the cord before touching or swapping any spade connections. Repair didn't go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
2等其他人完成本指南。
Ben Schlichter
于01/21/25注册
7,100 声望
创作了224篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 169
总计 910
