跳转到主内容
How to Blanket Stitch
你所需要的
  1. How to Blanket Stitch, How to Blanket Stitch: 步骤 1 中的图像 1,2 How to Blanket Stitch, How to Blanket Stitch: 步骤 1 中的图像 2,2
    • Pick a thread of your choice: fabric or sewing thread.
    • Cut a relatively long piece.
  2. How to Blanket Stitch: 步骤 2 中的图像 1,3 How to Blanket Stitch: 步骤 2 中的图像 2,3 How to Blanket Stitch: 步骤 2 中的图像 3,3
    • Pull one end of thread through the eye of the needle.
    • Make the two tail ends meet.
    • Tie a knot.
  3. How to Blanket Stitch: 步骤 3 中的图像 1,1
    • Lay your blanket (or piece of fabric) in front of you and pick your stitching direction.
    • We are stitching left to right!
  4. How to Blanket Stitch: 步骤 4 中的图像 1,2 How to Blanket Stitch: 步骤 4 中的图像 2,2
    • Measure about half an inch from the edge of your blanket and mark it.
    • Send your needle through the blanket from the back from the marked point.
    • When pushing your needle through the blanket make sure your fingers are not near the needle.
  5. How to Blanket Stitch: 步骤 5 中的图像 1,1
    • Bring the thread around the fabric and push the needle through the very first stich creating a loop.
    • Do not pull the thread all the way though, as you will need the loop for the next step.
  6. How to Blanket Stitch: 步骤 6 中的图像 1,2 How to Blanket Stitch: 步骤 6 中的图像 2,2
    • Push the needle through the loop and pull.
  7. How to Blanket Stitch: 步骤 7 中的图像 1,3 How to Blanket Stitch: 步骤 7 中的图像 2,3 How to Blanket Stitch: 步骤 7 中的图像 3,3
    • Move about half an inch from the first stitch.
    • Send the needle through the blanket from the back creating a loop.
  8. How to Blanket Stitch: 步骤 8 中的图像 1,2 How to Blanket Stitch: 步骤 8 中的图像 2,2
    • Push the needle through the loop and pull and repeat!
  9. How to Blanket Stitch: 步骤 9 中的图像 1,2 How to Blanket Stitch: 步骤 9 中的图像 2,2
    • Repeat the process through the edge of your blanket till you reach the end.
结论
To reverse these steps, use a pair of scissors to cut the thread.
2等其他人完成本指南。
katya
于05/10/21注册
223 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 84
总计 1,581
