跳转到主内容
How to Bind a Book Spine
你所需要的
  1. How to Bind a Book Spine, How to Bind a Book Spine: 步骤 1 中的图像 1,1
    • First, grab the book you would like to fix.
  2. How to Bind a Book Spine: 步骤 2 中的图像 1,1
    • Then, open the book to where you have the most access to the exposed inner spine.
  3. How to Bind a Book Spine: 步骤 3 中的图像 1,1
    • Shake up the glue before removing the cap.
    • Then, test glue on a piece of paper before placing it on the spine of the book. It should be about the consistency of Elmer's glue.
  4. How to Bind a Book Spine: 步骤 4 中的图像 1,1
    • Place the glue along the spine opposite of the cover. Make sure you are distributing glue evenly.
    • You may also choose to use a paint brush to make sure area is completely covered with glue.
    • Glue is runny; use with caution.
  5. How to Bind a Book Spine: 步骤 5 中的图像 1,1
    • After placing the glue, wrap the cover tightly around the book.
    • Firmly drag your fingers down the spine of the book to avoid any air pockets.
    • Remove any excess glue with a tissue.
    • For the demonstration we held the book as shown. You may also choose to place something on top of the book, such as a paperweight or another book, and let it sit for 30 to 40 minutes.
  6. How to Bind a Book Spine: 步骤 6 中的图像 1,1
    • After the glue is dry, you should be able to lightly tug on the pages without any movement.
    • If movement occurs then allow the glue an additional 10 to 15 minutes to dry. Once dry, you've completed your book repair.
结论
2等其他人完成本指南。
Britne Misner
于09/30/16注册
149 声望
撰写一个指南
团队
Missouri Western, Team 1-13, Adkins Fall 2016 Missouri Western, Team 1-13, Adkins Fall 2016 的会员
MWSU-ADKINS-F16S1G13
2 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 53
总计 2,247
