跳转到主内容
How to Apply Thermal Paste to Phones
你所需要的
  1. How to Apply Thermal Paste to Phones, Locate the thermal paste: 步骤 1 中的图像 1,2 How to Apply Thermal Paste to Phones, Locate the thermal paste: 步骤 1 中的图像 2,2
    • Look for existing thermal paste above or below the motherboard.
    • Thermal paste is often gray, but can be any color. It's opaque and thick, with a wet texture. Older thermal paste is drier.
  2. How to Apply Thermal Paste to Phones, Clean the motherboard: 步骤 2 中的图像 1,1
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from your phone's motherboard.
    • Don't use sharp or metal tools. They can scratch the motherboard surface or puncture the battery in an accident.
  3. How to Apply Thermal Paste to Phones, Clean the frame or cover: 步骤 3 中的图像 1,1
    • Scrape away large pieces of thermal paste from the frame or cover.
  4. How to Apply Thermal Paste to Phones, Prepare the motherboard: 步骤 4 中的图像 1,3 How to Apply Thermal Paste to Phones, Prepare the motherboard: 步骤 4 中的图像 2,3 How to Apply Thermal Paste to Phones, Prepare the motherboard: 步骤 4 中的图像 3,3
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  5. How to Apply Thermal Paste to Phones, Prepare the frame or cover: 步骤 5 中的图像 1,1
    • Clean the cover or frame using isopropyl alcohol and a coffee filter or lint-free cloth.
  6. How to Apply Thermal Paste to Phones, Apply new thermal paste: 步骤 6 中的图像 1,2 How to Apply Thermal Paste to Phones, Apply new thermal paste: 步骤 6 中的图像 2,2
    • Apply a small bead of thermal paste to the motherboard in the same location as the old thermal paste.
    • Unlike full-size processors found in computers with heatsinks, phones need very little thermal paste.
  7. How to Apply Thermal Paste to Phones, Continue reassembly: 步骤 7 中的图像 1,1
    • Return to your phone's guide to continue reassembly.
    • When you compress the thermal paste, it will evenly distribute and form a thermal bond with the processor.
结论
For other general electronics skills guides, click here.
27等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
95,853 声望
创作了466篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了15,909篇指南
5指南评论
What kind of thermal paste is best for phones?
Brian K - 回复
Your phone is less demanding than a full-size CPU in terms of heat transfer, so you can use any regular compound thermal paste.
Clay Eickemeyer -
Will applying thermal paste on smartphones be obsolete in the near future? I have a hint that my smartphone that is already 4 years old, now needs to renew its thermal paste because it overheats easily even while using lighter apps like the Calculator.
Koko Jeuru - 回复
Your phone is the same vintage as mine, and there was zero paste on mine (just a faint outline where it used to be). Just do it.
Animot -
do i need to apply just cooling film because my moto g6 plus had a film which got teared while replacing battery
Wasim Shaikh - 回复
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 172
过去 30 天: 782
总计 23,560
