你所需要的
视频概述
Switch off the keyboard by holding down the power button for at least 3 seconds
Open "System Preferences...", "Bluetooth".
Follow the steps to pair Your Keyboard
In my magic keyboard the tab and caps lock keys keep going on and off, randomly. I do not understand why and how to fix that. When they don't work I try resetting resetting the keyboard, but to no avail. Then suddenly they sort of wake up and work again. How's that?
Pupo Santi - 回复
4等其他人完成本指南。
4条评论
I bought a wireless keyboard at a flea market. When pairing I was able to enter all numbers, but the "Enter" key does not react. Is there some way to test the button?
Same for me. The problem was the enter key: there are 2 switches down the key but only the top one is pressed and this is broken. I removed the key, put a plastic spacer on the second switch and reassembled the key, all ok now.
ho provato a resettarla ma niente da fare funziona solo parzialmente .l’ho collegata all’iPad 11 pro e funziona perfettamente
victor
How can you do that if your keyboard isn't connected?
Jo Maz - 回复
