跳转到主内容
How to Alter the Waist of Jeans
你所需要的
  1. How to Alter the Waist of Jeans, How to Alter the Waist of Jeans: 步骤 1 中的图像 1,1
    • Put on the jeans and pinch the extra fabric at the centre back of the waistband.
  2. How to Alter the Waist of Jeans: 步骤 2 中的图像 1,1
    • Mark both sides of the pinched fabric with chalk on the outside of the jeans.
    • You may do this step while wearing the jeans.
  3. How to Alter the Waist of Jeans: 步骤 3 中的图像 1,3 How to Alter the Waist of Jeans: 步骤 3 中的图像 2,3 How to Alter the Waist of Jeans: 步骤 3 中的图像 3,3
    • Draw a diagonal line from each marked spot to the centre back seam.
  4. How to Alter the Waist of Jeans: 步骤 4 中的图像 1,2 How to Alter the Waist of Jeans: 步骤 4 中的图像 2,2
    • Pass the thread through the loop on the needle threader.
    • Pull the needle threader out of the eye of the needle and create a knot at the end.
    • Use a double thread or a thick thread for durability.
    • For more information on using a needle threader, use the How to Use a Needle Threader Guide.
  5. How to Alter the Waist of Jeans: 步骤 5 中的图像 1,2 How to Alter the Waist of Jeans: 步骤 5 中的图像 2,2
    • Begin sewing from the inside out, starting beside the belt loop.
    • Bring the needle across the marked spot and sew it inside out.
  6. How to Alter the Waist of Jeans: 步骤 6 中的图像 1,2 How to Alter the Waist of Jeans: 步骤 6 中的图像 2,2
    • Move the needle horizontally, then insert and thread it through the fabric a short distance below the starting point.
    • Repeat this process until the thread reaches the centre back seam.
  7. How to Alter the Waist of Jeans: 步骤 7 中的图像 1,3 How to Alter the Waist of Jeans: 步骤 7 中的图像 2,3 How to Alter the Waist of Jeans: 步骤 7 中的图像 3,3
    • Pull the thread to conceal the stitches.
  8. How to Alter the Waist of Jeans: 步骤 8 中的图像 1,2 How to Alter the Waist of Jeans: 步骤 8 中的图像 2,2
    • Bring the thread back to the inside of the jeans, tie a knot, and cut the excess thread.
  9. How to Alter the Waist of Jeans: 步骤 9 中的图像 1,1
    • Repeat steps 4-8 on the other side.
终点
另外一个人完成了本指南。
Zoe Kim
于09/19/23注册
215 声望
撰写一个指南
团队
York University, Team B-30, Woodhouse Fall 2023 York University, Team B-30, Woodhouse Fall 2023 的会员
YORK-WOODHOUSE-F23SBG30
1 名成员
创作了5篇指南
1指南评论
Thank you very much for your help. You showed me a new way to tighten the waist on jeans
Monika Skubij (Mon) - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 121
过去 30 天: 559
总计 5,505
