跳转到主内容
How to Alter a Large Dress to Fit
你所需要的
  1. How to Alter a Large Dress to Fit, How to Alter a Large Dress to Fit: 步骤 1 中的图像 1,1
    • Put on your dress.
    • Pinching the waistline, grab your ruler and measure from your hip.
    • This number will tell you how much you need to take in to make your dress fit.
  2. How to Alter a Large Dress to Fit: 步骤 2 中的图像 1,1
    • Turn your dress inside out and lay it on a smooth surface.
    • Using your measurements from Step 1, measure out evenly from the seam line how much you need to take in on each side.
    • As you measure how much you take in, use the clothespins as a marker.
  3. How to Alter a Large Dress to Fit: 步骤 4 中的图像 1,1
    • Carefully put on your dress to make sure that it fits you in the right way.
    • Now that your dress fits how you would like, carefully take it off and lay it back on a flat surface.
    • Using chalk or a pen, make a line that connects all the pins.
    • This line will be a guide for when you use the sewing machine.
  4. How to Alter a Large Dress to Fit: 步骤 6 中的图像 1,1
    • Thread your sewing machine.
    • If you need help on how to thread the sewing machine, here is a guide on how to.
    • Carefully push your dress through and begin sewing your new seam.
  5. How to Alter a Large Dress to Fit: 步骤 7 中的图像 1,1
    • When you're done sewing your dress, flip it so that it is right side out and put it on.
    • If there is any excess fabric, you can cut it away, leaving 1/4 of an inch of the leftover fabric by the seam.
结论
This is an easy and low budget way to fix a dress that is too large. Check the tag on the dress to see how you should care for it after. It is best recommended that you let your dress air dry.
另外一个人完成了本指南。
Viviane Dobis
于10/21/20注册
145 声望
撰写一个指南
团队
Texas Tech, Team S14-G7, Cowan Fall 2020 Texas Tech, Team S14-G7, Cowan Fall 2020 的会员
TTU-COWAN-F20S14G7
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 1,490
