跳转到主内容
How to Adjust a Violin Bow
  1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: 步骤 1 中的图像 1,2 How to Adjust a Violin Bow, How to Adjust a Violin Bow: 步骤 1 中的图像 2,2
    • Identify the adjusting screw at the butt end of the bow.
  2. How to Adjust a Violin Bow: 步骤 2 中的图像 1,1
    • Carefully unscrew the adjusting screw .
  3. How to Adjust a Violin Bow: 步骤 3 中的图像 1,1
    • Once you fully unscrew the adjusting screw, carefully remove both the frog and the adjusting screw from the bow.
  4. How to Adjust a Violin Bow: 步骤 4 中的图像 1,1
    • While not allowing the hair to become tangled, insert a small part of the adjusting screw so that only a small portion of the tip is seen. You do not need to screw the adjusting screw into the eyelet.
  5. How to Adjust a Violin Bow: 步骤 5 中的图像 1,2 How to Adjust a Violin Bow: 步骤 5 中的图像 2,2
    • Carefully move the adjusting screw to tighten the eyehole, moving in a clockwise direction. To loosen, move the eyehole in a counter-clockwise direction.
    • Do not screw more than 180 degrees during adjustment to ensure you do not damage the bow.
  6. How to Adjust a Violin Bow: 步骤 6 中的图像 1,1
    • Once you have either tightened or loosened the eyehole by 180 degrees, remove the adjusting screw from the eyehole.
    • Once you have finished, make sure the hairs are not tangled and have not become damaged during the adjusting process.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,125
