跳转到主内容
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
你所需要的
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 1 中的图像 1,1
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 2 中的图像 1,1
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 3 中的图像 1,2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 3 中的图像 2,2
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 4 中的图像 1,1
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 5 中的图像 1,2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 5 中的图像 2,2
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 6 中的图像 1,1
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 7 中的图像 1,3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 7 中的图像 2,3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: 步骤 7 中的图像 3,3
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
终点
2等其他人完成本指南。
Md Abdullah
于07/03/21注册
201 声望
撰写一个指南
团队
一条评论
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 206
总计 4,343
