跳转到主内容
How to Adjust Cantilever Bicycle Brakes
你所需要的
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 步骤 1 中的图像 1,3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 步骤 1 中的图像 2,3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 步骤 1 中的图像 3,3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: 步骤 2 中的图像 1,2 How to Adjust Cantilever Bicycle Brakes: 步骤 2 中的图像 2,2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: 步骤 3 中的图像 1,3 How to Adjust Cantilever Bicycle Brakes: 步骤 3 中的图像 2,3 How to Adjust Cantilever Bicycle Brakes: 步骤 3 中的图像 3,3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: 步骤 4 中的图像 1,1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: 步骤 5 中的图像 1,2 How to Adjust Cantilever Bicycle Brakes: 步骤 5 中的图像 2,2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: 步骤 6 中的图像 1,2 How to Adjust Cantilever Bicycle Brakes: 步骤 6 中的图像 2,2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: 步骤 7 中的图像 1,2 How to Adjust Cantilever Bicycle Brakes: 步骤 7 中的图像 2,2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: 步骤 8 中的图像 1,1
    • Flip the bike back onto its wheels.
结论
Go ride your bike!
另外一个人完成了本指南。
Devaughantee
于09/30/20注册
194 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 760
