跳转到主内容
How to Adjust Black and Decker TR1278B Browning Dial
你所需要的
  1. How to Adjust Black and Decker TR1278B Browning Dial, Top Cover: 步骤 1 中的图像 1,1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 2 中的图像 1,1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 3 中的图像 1,1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 4 中的图像 1,1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 5 中的图像 1,1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 步骤 6 中的图像 1,2 How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 步骤 6 中的图像 2,2
    • Remove the front cover.
  7. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 7 中的图像 1,2 How to Adjust Black and Decker TR1278B Browning Dial: 步骤 7 中的图像 2,2
    • Unscrew the circuit behind the browning dial on the front cover.
    • Do not lose the washers on the screws.
  8. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 8 中的图像 1,1
    • Remove the circuit.
    • The dial and buttons on the front cover will be loose.
  9. How to Adjust Black and Decker TR1278B Browning Dial: 步骤 9 中的图像 1,1
    • Turn the knob on the circuit board left or right to adjust the browning dial.
结论
Dominic Gamonez
于02/15/17注册
248 声望
创作了2篇指南
团队
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 19
总计 704
